Newbie Build - Need Mobo Advice
Emmeff
Hi,
I'm looking for info on which Mobo to use with Intel i5 Haswell 4670k 3.40Ghz. First time build, so any advice appreciated! Will be sourcing from UK retailer.
The 4670k is a 1150, so you should get a 1150 motherboard.
The motherboard has to have a chipset starting with the letter z if you ever want to overclock that CPU.
Any Z87 motherboard, depending on what brand you like and what features you need and can afford.
I would go for either the Asus Z87-A or the Gigabyte UD4H. Both are good boards with a lot of community support.
