mrmagoo_83
- Aug 8, 2002
Computers I know, RAID I do not, so I need a little help on what it will take to do what I am wanting to do. I have done some research, but nothing really pops out as "what to do if you want to do this" type information.
I have a 1U server, as well as a 4U Machine. Nothing fancy, just some acquirements I received. My plan was to throw in an IcyDock 5x3 SATA cage into the 4U machine, and use it as media storage, combine it with a sixth drive for redundancy. I am guessing RAID 5 would probably be best, or would RAID 1 be better? I want it so that if a drive crashes I dont lose it all or lose any part of it. Speed isn't really that big of an issue, as it is just a media server for movies, music, and pictures that will be streamed via wireless network to my HTPC in the living room.
The question, is I guess I need a motherboard, or RAID card that will handle 6 drives SATA drives, correct? With that said, if I get a motherboard with say 10 connectors, can I use 1 connector as a regular drive, and then 6 for the RAID, or when I tell the motherboard I want to use RAID does it put all the SATA connectors into RAID mode?
