Newb SSD related question (Raid)
I tell you what. Just send me the Revo and viola', PCIe slot problem solved.
The Revodrive is PCIe, right? You can't do actual RAID unless both drives are on the same controller, which the Revo obviously wouldn't be. You might be able to do some kind of OS level RAID, but I'm not sure what the advantage of that would be for you. Why do you need to RAID the drives, as opposed to having two drives in the system?
