newb questions..match memory speed with FSB?
MysticX23
newb questions..do we need to match memory speed with FSB? never had that prob before cuz always used rdram and that limited me with only a few choices...
...but now i wanna dump my rdram get the athlon 3000 400mhz bus...so i'm wondering if i need to get my ram to match the 400mhz bus of the athlon (ddr400/pc3200)..is this the optimal setup or they have nothing to do with each other?
then i got a question about the difference between ram...on the anandtech price guide i see several pc3200 512mb stick of ram ranging from corsair's "value" at $80ish to kingston's "hyperx"..whats the difference and how much performance diference will there be?
thanks
AMD's require matched fsb/memory speed for optimum performance.
As for the differences in ram, usually the higher price the ram is the better the latency(speed). The lower the cas is, the faster the memory functions. Most value ram is cas 3, and tends to run at it's stated specs allowing little to nothing in the area of overclocking the ram. The higher priced ram usually has very low latency and allows for the ram to be tweaked more with voltage adjustments.
If you are planning on leaving the 3000 at stock speeds it would be fine to look for some cas 2.5 pc3200.
This is a decent bang for buck memory with cas 3 latency
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-480&catalog=147&depa=0
also, for more in depth info check out this thread
http://hardforum.com/showthread.php?s=&threadid=707289
so according to that thread...amd's (alhtough cheaper) are much harder to overclock because the memory is the bottleneck and the FSB and memory speed MUST match for almost all cases. Therefore, I need to get higher speed memory, ddr3500, if i oc my fsb higher right?
then for Intel's, dual channel speeds must be less than that of the FSB for optimal performance, right?...and making sure, the 800mhz fsb = ddr400 when matched?
You do not *need* pc3500 to overclock an Athlon system. Most Athlon Overclockers simply push their FSB to 400. With this, pc3200 left stock is fine, because they are matched. If you choose to get some of the more expensive RAM, you can easily push your frontside bus higher keeping a 1:1 ratio. This thread seems to be using Corsair as an example. If you get their $80 value stuff, you're not going to go higher than 400 easily. If you get their Low Latency XMS, 440 is well within reach.
