Ok. First let me preface this by saying that I did read the sticky threads at the top. However, my computer knowledge is not as good as it should be and I still feel that I need a bit of guidance. The problem I have is that there are too many recommendations in the threads and I guess I just want someone to tell me 1) yes/no you need a new PSU. 2) This is the PSU you need to get.
I have a Gateway 7200XL (Here are the specs http://support.gateway.com/s/PC/720...l?sourceid=00390999248235080764&AFID=BEFREE01)
It has the following components:
915G Express Chipset
Intel 640 3.2 Ghz
4 sticks of pc3200 DDR ram = 768MB
1 160GB IDE HD
1 Memory Card reader
1 DVD RW drive
2 * 120mm fan
MSI GeForce 6600GT
Linksys Wireless G PCI Network Card
Crappy PCI Sound Card
Wireless USB Keyboard/Mouse
The case has a 300W power supply. I used the wattage calculator in the aforementioned sticky threads as well as others on the internet and they tell me that I need a 300W power supply. My question is whether I am pushing my luck? If I am, I dont mind getting a replacement, but if I do, I have no idea which one I should get. Any help? I guess my budget for a new PSU is about $50 but I'm flexible if it is necessary. Thanks in advance.
Intel 640 3.2 Ghz
1 160GB IDE HD
1 DVD RW drive
2 * 120mm fan
MSI GeForce 6600GT
