New workstations
DarthBeavis
I built these for my clinic as I did not want to shell out the scratch for more iMacs . . .
Specs:
-Danger Den Tower 16 cases in Bruiser color scheme and custom etching
-Q6600 G0 revision
-2 gigs Crucial Ballistix Tracer
-Intel Intel DG45 mobos
-500 GD WD Green HDD
-Using Integrated GPU
-Two Yate Loon H fans
I need to reapply the side window film that looks like stained glass . . .have to trim it so bubbles do not form . . .may or may not leave the film in.
We may have conflicting styles, but I respect the work you do. Nice take on a "workstation". Wish I was using something like that at my office!
May I ask what kind of clinic you operate so that I may fully understand why you chose these specs and designs?
Veterinary clinic . . .which will not help you with the designs . . .
We have probably 90-95% women . . .yet some pretty rugged and tough women ;) I was just experimenting with the stained glass stuff to see how it came out . . .
Google DarthBeavis to understand the insanity ;) These cases are mild sauce compared to my normal builds.
Specs are minimal I think . . .
Nice work. I like the stained glass, I bet it would look good on a receptionist desk.
If it was my personal rig it would be air-brushed by Smooth Creations . . .
The material is that stuff they carry at Lowes and Home Depot . . .they have tons of designs. It goes on really easy . . .just spray window with water with a little soap in it . . .peel off backing and squeegee on . . .it comes right off if you peel it with NO residue!!!!
What's with the random openings and lack of IO panel on the backs of the cases?
I am having the IO plates painted . . .no immediate need for them since I am using onboard video . . .
Slots in the back are for ventilation . . .fans on front blow air through towards back.
Neat machines, but since its a vet clinic I would want no exposed holes on the machines. Nothing like animal fur getting into all the nooks and crannys of the machine to make all that pretty work look out of place.
It needs some grill cloth or other type of protective material.
Just a thought.
Just a thought.
I installed fan grills in the server I build . . .good idea . . have a few extra . . .will pop them on
I remember some of your previous work like the Globe. Either way nice job with stain glass look.
Just a thought.
How does this look ;)
