New wireless router - 155Mbps internert
annilation
Just upgraded to 155Mpbs internet at home and my MR18 is struggling to do over 80. Looking for something to replace it with.
Prefer a router/wifi combo not just a wap unless it is that good.
Is the DLink better than the Archer C7?
The router board looks like a little too much work. I cannot find a case or even people building it as guides.
It's faster by quite a bit, Dual Core 880Mhz vs Single core 720Mhz
Same amout of RAM and USB3 instead of USB2.
What about the wireless throughput? That's my main concern with it being AC 1200 instead 1750.
Also think I would get the B1 if I order through Amazon or do I need to hit Best Buy to confirm?
I would probably go to BB to avoid the hassle, as far as 11ac goes I can confirm that I get connection and it seems to work just fine using my cell phone but not any record breaking speeds. I do doubt that my phone will ever such speeds however.
While researching found out about T-Mobile gives away a branded asus AC68UT. Picked one up yesterday, it was only a $25 deposit!
Hitting 190-210 Mbps on wireless. Thanks about the Dlink was about to pull the trigger.
