Hi all,
Thanks for lookin in.
I finally took the "Plunge" a purchased a WC "kit". It was through Petra's (MAD PROPS to ALEX for the excellent service and support he has provided!).
I ended up getting the PetraTech's CoolKit Elite: http://www.petrastechshop.com/pecoel.html
The main reason for that kit was the Storm (rev 2) CPU waterblock. I also picked up a Swiftech MCW60 GPU block... I decided against the NB block as well as anything with a lucite top (no offense - DD fans).
Alex was kind enough to upgrade two pairs of the barbs with EK 1/2" barbs. I've already asked Alex, what I needed to do to install the EK barbs to the Storm and was told to use the Storm's O-rings in conjunction with the built in O-rings on the EK barbs to ensure a good seal. I did that.
So the question I have is... where would you use the other pair of EK barbs? GPU waterblock? Raidiator? Resevoir? (also got the Swiftech Mircores). I assume if I use the barbs on a fitting where there's a recess (like the STORM), I should use additional O-rings, but if the contact surface is not recessed (raidiator), then the built in O-ring on the EK barb is sufficient. Also... since the threading is shorter on the EK barbs, do you guys who have them still use teflon tape (or other thread sealant)?
TIA!
P.S. everything has had its vinegar bath, and distilled water rinsings.. I'll be leak testing the system tomorrow and hopefully OC'n the hell outta my Opty very soon.
TIA!
