Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I STRONGLY suggest that you DIY. Your system looks pretty good. Can you include prices of what parts you are getting so I might be able to save you some money?
I suggest an acetal Maze4 and RAMsinks for your GPU. The NV-68 is prone to bad mountings.
Do you have fans for your rad?
And you definitely don't need 20 feet of tubing, 10 is more popular.
Swiftedch's new "kit" is just their BIPII, D5, Storm, & bay reservoir put in a bundle. You still have to assemble the tubing & make all the connections, but the top components are in this kit, so it is no performance slacker. It would still be much better for people to do their own research before they buy anything, but this kit is going in the right direction performance wise.
