- Dec 9, 2000
yeah you can run any two pumps back to back in your loop for redundancy, in a "serial" configuration, i'm currently running a PMP-500 > MCP-355
So it will work even when they have different flow rates ?
I found one of these locally, specs seem ok (800LPH), any input?
http://www.techpowerup.com/193809/ek-introduces-the-dcp-4-0-x-res-combo-pump-reservoir-unit.html
EK.....meh. After their waterblock asshat moves a couple years ago I wouldn't buy their stuff if they were giving it away.
I've never run two pumps at the same time? I can't see an advantage.
If one fails pump #2 can maintain flow.
Btw if one siezes wouldn't it block flow? In that case parallel with 2 y splitters sounds better .(just thinking out loud, I'm a WC newb)
I'm not really worried about failure.
My oldest 655 is pushing 6 years in at least three systems, still works like a champ and no reason to even think about replacement yet......if it does, then I get to buy all new stuff.![]()
Well I'm worried about downtimeand possible equipment failures if the pump fails!
but i'm sure overheat protection will kick in and shutdown the system anyway
Yes, your system will shut down if it gets too hot.
You still have down-time to figure out where the failure is and replace it, so you can't escape that.
As I said, if the whole thing blows up.....I get to buy new stuff!![]()
What brand and type of tubing do I want to look at ?
Pressure fittings vs barbs + clamps? if barbs + clamps what type of clamps are preferred?
I used to use barbs plus clamps, but compression fittings (if tubing cut correctly) are very reliable in my opinion. My entire system with 16 barbs are all compression fittings and haven't had a problem so far. Though the compression fittings sometimes need extenders to work with some case areas and water blocks. It adds up quickly!
The barbs+clamps would leak sometimes due to the clamps not putting equal pressure around the tubing causing warping and leaking over time. Inexpensive compared to compression, but I don't like doing the clamps anymore.
Is 900lph going to be enough for 3 rads(360) and four GPU blocks!?
I've never had a leak with barbs, however compression fittings do sound interesting, how do they work?
Thanks for the info too :
Danner mag 7-9I'm planning on wcing my mining rigs in the next few months. It will need to cool two 290xs and two 280xs, no CPU. I'm also considering leaving the rads submerged in a small kiddy pool of water in the shade outside and running the water lines into my basement. But let's assume I'm using fans to cool the rads;
Is it better to run two smaller loops? Or one big one with a better pump?
How many rads and what size will I need?
What type of pump would fulfill the requirement for both scenarios.
