robble
- Jun 6, 2004
Since o/c'ing my 7970 on water I've had to turn down the OC on my cpu to keep temps in check. My swiftech 240 radiator just can't keep up with that much heat.
I had been racking my brain trying to figure out how to tastefully add more cooling power to my loop for the last week or two. I just couldn't figure out how to add a 320 or 420 radiator using my current case without a Frankenstein look.
Then I saw the NZXT 810 case and fell in love. It has room internally for both radiators and looks great to boot!
After lots more research this is what I pulled the trigger on last night at Jab-Tech:
Amazon just listed the NZXT 810 case on the website but they aren't in stock yet. I went ahead and placed an order anyway since I get dirt cheap 2nd day air shipping using prime. Hopefully they receive them soon.
I plan on using the six ap-14's in push pull on the gtx360. I have an ap-15 and noctua fan on the 240.
Now I am racking my brain on how to route the hoses. I suspect the pump will be on the power supply, the reservoir mounted on the rear of the case covering the 4 rubber gromits for hoses.
This represents the general placement for the stuffs. What hose routing would you recommend?
