New Walmart build for friend
Dim8400
Please use http://www.walmart.com/ip/iBuyPower...thod=Recommendation:wm:RecentlyViewedItems#rr for build. Only source he can afford to buy from. (Walmart card)
Gaming such as Guild wars 2....star trek online.....Needs to be able to keep up with newer games
$950 before taxes and shipping
USA Richmond VA
4) What exact parts do you need for that budget? CPU, RAM, case, Mobo. Whats offered on the walmart build site. No monitor or keyboard needed.
5) If reusing any parts, what parts will you be reusing? Monitor, Keyboard
6) Will you be overclocking?
No.
7) 7) What is the max resolution of your monitor? What size is it?
19inch 1440 x 900 plan on upgrading to 23+ inch 1920x1080
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Choices are limited by whats on the website. Best for the money.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, he does. But the pc comes with 7 home.
This build is for a friend who does not feel comfortable building one on his own and he needs a new PC ASAP. His old pc is dieing. I understand it is not the best route to go and if I could I would build one for him but hes several states away and is asking for my help. I built one on the website but needs opinions.
Here is what I built for him:
It is a bit on the conservative side to save him some bucks and get good performance.
Case: NZXT Guardian 921 RB Chassis, Red
MOBO/CPU: Intel Core i5 2400 Quad Core Proces ...
RAM: 2 x 2GB = 4GB DDR3-1333 Gaming Grad ...
HDD: I chose the SSD option but I understand not all SSD's are created equal.
Video Card: AMD Radeon HD6850 1GB Video Card
24X DVD+/-RW DL Optical Drive
Home 7
64-Bit Edition
Bundle Total:
$879.00
Appreciate all the help. :)
NZXT Gamma Gaming Case, Black
Intel Sandy Bridge Core i5 2500K (3.3GHz) Processor
4 x 2GB = 8GB DDR3-1333 Gaming Grade Memory Module
iBUYPOWER 120GB 2.5" SATA Desktop Solid State Drive
ATI Radeon HD 6870 1GB Video Card with 800W Power Supply
Microsoft Windows 7 Home Premium, 64-Bit Edition
Total 959 dollars (9 dollars over his limit though).
No idea about the SSD, but this is the best I could do. He could drop to 4 gigs of ram and knock off 20 bucks if he wanted to, but it's not a bad deal (though the capacity is pretty shitty for what's available now)
If he isn't overclocking, no reason what-so-ever to go with a 2500k unless it's cheaper than the 2400. Also I'd look for a 2x4GB kit of RAM, instead of 2GB modules. It limits future upgrade possibilities.
