New volume tray tool
SvenBent
i always haetd how the standard volume tray tool in windows only show master channel if you clicked it.
Ive made my own little icon instead that show the full volume unit when you do so
it alos creat hotkeys for non media keyboard to control volume
Win+Pageup = Volume up 2%
Win+Pagedown = Volume down 2%
win+end = mute toggle
I am looking for some feedback and suggestion to improvements
http://www.filedropper.com/sbvolume_1
To Do list:
- More icons selections ( suggestioens wanted)
- Reduce memory usage (easy)
- Installer with autostart
I would have a look at it, if you included an image or screen-shot of what the change(s) are.
I appreciate you've described it, but it's not clear to me exactly how yours is different from your comments.
Right clicking on the standard volume icon in the system tray and choosing "volume mixer" to see all channels isn't exactly a burden or a chore either - so being blunt - I'm really not sure why I would choose to add another piece of software to my system.
Lastly I personally would prefer to not download an executable file for something like this. Do you have it in ZIP format for a manual installation ?
I'm not meaning to be critical of you or your software - just providing feedback from my own perspective.
At the moment though I kind of think you're trying to fix something that isn't really an issue... to me anyway.
