OK, I'm new to this forum, and while I'm not new to computers / programming / video editing / gaming, but I'm by no means an expert. I work for a research lab, and we have need of updating our video archiving system. Currently, we're using 8mm cam's, which is very frustrating when you need dvd's made for lawyers. So... I'm looking into updating this to a digital system, and have spec'ed out the following:
Motherboard Intel D925XCV
Processor P4 3.0 GHz
Memory Kingston DDR2 1GB
Storage WD 250GB SATA 7200 rpm (2 in RAID 0)
Graphics ATI Radeon x700 pro 256 MB
Drive DVD Burner ???
Power Supply ???
Case General ATX supported case???
Case Fan ???
Video Capture Canopus DVStorm2 pro
The lab basically tests smoke detectors, and we have 2 camera's running for each test. I need a system that would be able to capture both feeds simultaneously (DVStorm supports this) and allows me to archive the information as quickly as possible to Hard drive, or DVD. Each test usually runs about an hour in length, so the data piles up quickly. There will be a small bit of editing, probably a picture-in-picture filter, and I want the render and encoding time to be as short as possible. The decision on whether to just burn everything to DVD or to just back it up on removable hard drives and burn DVD's as needed has not been made yet, and I welcome any advice. Keep in mind that the sky is not the limit, and I do need to keep this as cost efficent as possible, while still getting the job done.
I have talked to a few people who recommend dual processors, and AMD, but i've heard that intel's are better at video. (My personal comp is AMD, though) I'm open to any and all suggestions / comments / questions / criticisms...
Wes
Power Supply ???
Case Fan ???
Wes
