New Upgrade Parts - But Won't POST!
waterboy787
All-
Just upgraded to get a mobile 2400xp 35 watt and 1 gig of PC3200 mushkin ram running dual channel. In addition picked up a SP-97.
The thing is, after installing these components my Shuttle AN35N Ultra board won't even POST. It was working earlier tonight with my old 2400xp and 1 gig of crucial ram!
I've stripped it down to the hd, vid card now. It doesn't even make any beeping noises and nothing shows up on screen.
I've also tried reseating the heatsink..and the core isn't cracked as far as I can tell. Any suggestions??
Thanks.
Will your mobo support a mobile cpu.
I would put your old cpu back in and see if it posts.
If it does then you may need to check that your bios will support a mobile.
If it does not then see it a bios flash will help.
Luck..... :D
