New Unreal Engine 4 | Effects Cave Tech Demo |
www.youtube.com/v/7CGBoFZq1dU
Remember to select 4K video quality
Where's the Mantle-powered CG?
That was a Skyrim dragon model pulled out and imported into the U4 engine. I watched a guy do it on youtube to see if he could do it.This has been available for like a week or two now.
UE4 is pretty neat.
edit: also what does Skyrim have to do with UE4
I really like the default AA you can't see it on crappy YouTube video but it's like txaa but cleaner less soft look. The cave démo run at 45-65fps in 1440p on my 780oc. It's good because it's just a cluster of special effects
Here a link to download them
http://forum.benchmark.pl/topic/125341-unreal-engine-4-realistic-rendering-room-demo-do-pobrania/
The cave one you have to edit a INI file to select resolution. Also they need visual c++ 2013 to be install, avaliable on ms website.
Link is virus safe I tried them all
I thought the water effect was the worst thing about the video... clearly seeing sprites being used on emitters for the "splash" effect.They're getting closer. The water effects are into the uncanny valley.
I'm sure the UE4 games on Xbone and PS4 will look just like this.
The bridge is rocking. At what resolution did you watch the video?I thought the water effect was the worst thing about the video... clearly seeing sprites being used on emitters for the "splash" effect.
Actually, I wasn't a fan of this video, there is an overblown contrast and blurriness to the video/textures... the particle effects outside just looked too random with little depth (they all seem to be 1-5 feet away from the camera) and the fire particles are clipping through the statue breaking any sense that that is real. The bridge outside is also very stiff, I'd think it'd be rocking a little... and those ropes don't look right either... nothing interesting design-wise either, like they picked some very boring locations to try and emulate...
The worst UE4 showcase yet IMO
@ Occidio
Those aren't UE4 screenshots, it's 100% modded Skyrim.
http://enbseries.enbdev.com/forum/viewtopic.php?f=14&t=17&p=49859#p49859
