New Typhoon for silent HTPC
jon67
Looking for a CPU cooling upgrade for my HTPC with a P4 3.4GHz (550) a TDP of 115 W. Currently have the Zalman 7700Cu which is ok, but I feel there must be a more efficient and silent solution with heatpipes. I'm considering the new Thermatake Big Typhoon upgrade (VX) because of its perfomance/noise ratio and it's easy to install on LGA775.
http://www.thermaltakeusa.com/product/Cooler/Retail/cl-p0310/cl-p0310.asp
The cabinet is pretty small with an internal width of 170 mm. The side panel opposite of the motherboard has an opening/grill with 105 mm diameter located above the CPU socket. I've found that there will be about 10 mm of headroom between the side wall grill and the fan intake on the Typhoon. How does this setup sound? I'm reckoning the 120 mm fan will be powerful enough to pull in outside air through the grill. Anybody else using Typhoons in small cabinets? Grateful for any input.
I've tried the cnps9500, 2 water cooling solutions, and the big typhoon....I'm using the big typhoon again. It's SO quiet, it's impossible to use even watercooling as the pumps make too much noise in comparison.
Highly recommended if it fits in your case, and the cooling is better than water cooling in my situation (I've tried the thermaltake silent whatever & the natilous 500 (sp?) by corsair...both didn't cool as well as my BT.
Ya, that looks like a cool solution if you don't want to take the mb out of your case (PUN!), even though I think all the hub bub about the 'pain to install' on the BT is overblown. Maybe I'm just an expert at it by now? ;)
I have the typhoon and it does it the job. I builded my kids rigs and my own the typhoon was the only choice since then I have upgraded the cpus from intel 820D's to 950D's and no hiccups
