New TV - LCD Viewsonic vs Olevia
brighton
Im looking to get a fairly cheap 32" LCD TV so far these are the choices. The Olevia seems like the best choice.
Olevia http://www.newegg.com/Product/Product.asp?Item=N82E16824022006
1600:1 contrast
Viewsonic
http://www.newegg.com/Product/Product.asp?Item=N82E16889107008
1000:1 c
Westinghouse
1000:1 c
http://www.newegg.com/Product/Product.asp?Item=N82E16824234002
or may be even this Hyundai http://www.newegg.com/Product/Product.asp?Item=N82E16824179023
1000:1 c
pretty sure all three have the same 1 year warranty
I dont know about the 32" olevia but I have the 27" version and it is awesome. My only beef with it is the low resolution 1280x1024 it can hit. If you are going to do any gaming go with the one with the highest resolution and lowest reponse time. While I am on that note it would help others give feedback if you state what you are going to use it for (gaming, movies, TV, movies, v-editing etc...).
ok im leaning toward getting the olevia just bcuz of teh 1600:1 contrast, it doesnt have HDMI and no HD tuner but i dont think i need these? My DVD player only has component and s-video hookups.
Im using the TV mostly for DVD and TV nothing else well i will have a comp hooked up to it but just to mess around.
thx
So I got the Olevia 32" all i can say is WOW this TV is awesome. me and my roommate were speechless watching Batman Begins in HD it was that good. can't wait till my DVI cable comes in :)
My only con so far is that it has no HDMI but its not a big deal bcuz you can get a DVI to HDMI cable.
