New to website building - Question
Le037
Sup so I wanted to start building my own website. I have no idea how this works. I downloaded Dreamweaver, but the only way to work with it seems to be writing the code line by line am I wrong? Doesn't this take too long? What do people use to build websites?
I use DreamWeaver CS4 and I write everything by hand. I use Joomla for content management, and DreamWeaver mainly as a file manager and uploader.
You don't have to do it all line by line code wise, though this often results in the best code. Go into the Design view, you can place items using the menu on the right, images, text, div tags etc etc. and it'll generate the code for you.
You downloaded Dreamweaver, huh?
If you wanna know what you're doing, you have to code it yourself. I like Notepad++. Dreamweaver is one of the better WYSIWYG editors, as it doesn't input tons of junk code like other editors. But if something isn't working right, you're gonna need to know what's going on code-wise.
Thanks yeah Design view is way more comfortable. Yeah I downloaded it and am using the trial version. So this is the most popular program used to make websites huh? Guess you can make anything with it?
I have tried a many of the alternate programs. Before upgrading to CS4, I tried a number of free open source options, and I still came back to Dreamweaver. Once you get to the point of having multiple sites, a test server, etc, Dreamweaver becomes pretty handy in the way it manages the files.
I've only been doing this stuff for about a month, and dreamweaver is fantastic, really it is. Its like all of the CS products, I really can't fathom how powerful they are but they destroy everything I try and beat them with.
