New to watercooling
Smoked Brisket
Ok so last year I installed the xspc rx360 kit to my socket 2011 system( rampage 4 x and 3820) It has been running great, temps are in the mid to high 30's most times. I have a gtx Titan and now want to watercool the gpu. I have ordered an rx120 radiator and plan on upgrading the loop to the following configuration:
Pump to triple rad to chip to single rad to gpu back to pump.
I have the swiftech d5 pump radiator combo pushing the water, Mountain mods case.
Do I have enough pump?
Is this a good configuration?
Will my loop stabilize at the temp of the hottest component? The Titan usual stays consistently at about 79 when gaming. What can i expect. My rads have fans on both sides in a push pull configuration. Is that the best way?
I am not overclocking.
TIA
Yep d5 will do it no problem.
I did 360 rad, 240 rad, cpu, and crossfire with my d5
So is my configuration correct? Can I expect a big increase in temps on the CPU after adding the gpu to the loop?
