New to Water Cooling
Hyuukai
Ok i have built quite a few Pc's and i have always used fans. I have been tempted by watercooling but things have stopped me
Being worried about leaks:
Knowing very little about water cooling:
Knowing nobody that has every done water cooling:
Worried about things going wrong:
That aside im very tempted to try my first water cooled PC. I have the PC parts but i need help from there. I know everyone has to start somewhere so im sure somebody who went through the same kinda thing can applicate this.
thanks for your time and help!
Well the first thing we need to know is:
Case?
Motherboard?
CPU?
What do you want to watercool... ie: CPU, CPU+NB, CPU+NB+SB+Mosfets?
How much do you want to spend?
And your worries are all normal, I have never watercooled but working out my build list has been ongoing for over a month and a half, doing tons of research. As for your actual worry list the only thing that worries me is the possibility of a leak... but I think if you take your time and get good hardware and do a little research it will all pay off in the end. Also, I feel confident because I have owned a car now for about 23 yrs and never once did it leak... and all due to proper maintenance, which I would think would also hold true to a water cooled computer
Don't be afraid to ask (as long as you read similar threads and use the search function first)!
Key to successfully setting up a loop is going nice and slow. Every time I rush, I end up with a mess everywhere.
As for worrying about things going wrong, it took me a long time to push the power button for the first time, but I've stopped worrying ever since. Not everybody is the same though.
As far as leaks are concerned, use a coolant like FluidXP or the new FeserOne. They are are non-conductive and will not damage your hardware if a leak does occur. To be honest I've been on water for about 4 months now and i haven't even thought about it. Hasn't leaked once, even after multiple LAN parties and a trip to Kentucky for LanWar back in January. I have a lot of connections in my loop too. CPU, NB, SB, Vid, 2 radiators and a pump.
Ah cool wouldnt be worried about a leak if i used that! and concering the guy asking about what i want to cool is i want a complete watercooled setup, how dependant is it on the components you have i dont wanna have to pay out for water cooling then when i upgrade my pc have to get a new one
its reccomended to use transparent tubs,its to much wire together .try to rearrangement the wire and tubing,waht coolant use,dont try to use a regular coolant,distiled water or something like this,its risqi,use only specified coolants
FluidXP and FeasrOne aren't any more "non-conductive" than pure distilled water. Period. No matter what the manufacturers tell you.
Leaks pretty much don't happen if you:
1. Properly leak test (at least 24 hours, loop complete outside the case on a surface where it will be obvious if there is a leak)
2. Properly clamp connections
3. Do not use total crap tubing
4. Properly leak test. Cannot stress this one enough.
With recent advances in air cooling, unless you're going for super high OCs or total silence, you may honestly be better off from both a relative hassle and relative financial drain perspective to go with high end air cooling. A full water loop (3x120 + 2x120 radiators, radiator grills, pump, full coverage GPU block, CPU block, northbridge block, tubing, reservoir) can /easily/ get up to the $400 mark.
You may add me on MSN. My address is in my profile. I can answer any question you might have, in real time, if you'd like.
Your concerns are normal, but just know, with proper planning and leak checking, water cooling isn't any less safe than using a huge heatsink. Never rely on a non-conductive coolant. Truth is, they become conductive, over time. With the proper clamps, tubing and fittings, leaking will be the least of your worries, TBH :).
Leaks aren't that big a deal. Not too long ago had one that dropped coolant all over my vid card, sound card, and nic card - and not just a few drops. Alcohol swab followed by 10 minutes or so with a hair dryer and was back in business. Have seen a number of posts now describing panic attacks following leaks then followed up by well nothing bad happened.
You make it sound like it's impossible to kill stuff. It's not -- you just got lucky and didn't hit any comparatively high voltage components.
I recommend distilled water with maybe a little (5-10%) antifreeze to prevent algae. Distilled water is non-conductive and the best coolant, marketed fluids are a waste of money. Most people start by cooling CPU and GPU, this is where you should start. If you are going for high FSB overclocks, consider cooling the NB as well. Blocks are normally pretty universal, current ones come with multiple brackets that will fit AM2 or LGA775 generally. Full-cover GPU blocks aren't very versatile, normally being designed for a specific series of cards. There is no need to worry about leaks as long as you properly leak test before hand and after you transport your case in the car or something. Check the guides in the sticky to find out what rad/s you need to cool your system and read around.
Nah not was I'm trying to say. Only that leaks don't always necessarily mean immediate death.
Well, I've had a few leaks over the years, and never suffered any damage. Just shut down fast, and dry the area.
Yep, QFT. The feser one coolant is the best that I've found, if you HAVE to use one though... But I'd never run anything but distilled water with a 1% antifreeze and about 10drops / L of PT nuke.
