New to vbscript and looking for simple help
DarkRukia
Ok so far I have the following:
intReply = MsgBox ("Your system has encountered a critical error, Windows will continue to shut down your system." , vbCritical + vbOKOnly ,"System Failure" )
And I want to follow up, so far this is the image that appears when you click the .vbs file
Basically I want to learn how to make hitting the OK button follow up to do something such as open a program or even restart the computer.
I also want to make it so when you go to the file on a sites directory such as say the files name was Dan.vbs and when you go to the site/Dan.vbs instead of showing the text actually execute the pop up.
Can anyone help?
If intReply = 1 Then
Else
End If
You could echo the values to figure out how to use them:
WScript.echo intReply
