New to SFF's need guidance
johnjohn
Well i need a rig for lanning and home.. my current rig is a P.O.S. cant run games and my old one thats for gaming fried up.. so im getting a cpu/vga/ram traded HL2 for them..
so i need a SFF nonthing to fancy but i am intersted in the shuttles possibly the SN21G5 or etc..my rig will consist of --
3500+ Newcastle core 2.2ghz socket 939
1GB Kingston Value ram (512mb x2)
eVga Geforce 6600gt pci-express
80gb sata hard drive 7200rpm
dvd-rw optical drive
but the trick is if i get a shuttle then all i gotta do is buy a shuttle nonthing else right, well thanks alot i appreciate it guys
Respectfully,
john
Shuttles are good. Keep in mind they don't upgrade as the mobo is what it is. Other SFF cases take mATX motherboards and are good for people that make upgrades....these are a little bit bigger though!
Welcome to the world of SFF by the way :) If you have any questions please feel free to PM some of our experts haha.
For a shuttle?
I would get the SN25P unless you wish to go AM2 (which i recommend since it is not that much more).
If you do AM2 then get the new shuttle for AM2 SN27P2.
help me narrow the choices so far i like
SN25P and SN21G5
SN25P because sli? etc..
SN21G5 because smallest etc
but how ever i hear the 21G5 has some aircooling problems bios problems runs hotter then the SN25P thanks alot. buying the SFF as soon as parts are shipped or maybe ill wait to find out which SFF to get.
SN25P and SN21G5
How much are you gonna be moving around with it? If a lot, the 21G5 might be better due to size, but if you dont mind the little bigger 25P, then the option of future SLI upgrade might be applealing.
ps. welcome to SFF, I love it here, lol :D :cool:
i mean ill be honest i dont move alot , but i just want a very small one.. whats difference of 25 and 21g5? cooling difference , bios overclocking etc? but ill lan. :) thnx.
The SN25p is not SLi the SN26 is.
the SN25 just has a better motherbaord and better cooling.
Also, are you dead set on a shuttle?
Because if you are not and don't mind getting a bit bigger, the Micro Fly is a really good option. I have my opty 146 @ 2.8 on stock volts. Temps even after days of stress testing never went past 46, and stayed at 45 most of the time. BTW- the ambient in my room is nearly 28 degrees (a bit above 80 fahrenheit). If you are concerned about cooling and want the best upgradability, the Micro Fly is the way to go :D
Well, depends on what you wanna spend. For a higher price you can get the SG01 or extremely higher price the Qmicra...both have what you want :)
ahh, thanks for the heads up, my mistake ;)
well i like the style of shuttle i dont need * room and expandibility * for this rig.. just this rig will be a lanning / back up pc. going cheap. so yeah just 6600gt / 1gig ram / 3500+ thats it.. aslong it games . i am proud lol
then getting SG01. :) for my main. but can the Sn25P fit a X850XT <-- dual slotted videocard
