New to SAS need advice
I got 2 serial attach SCSI hard drives and I have no idea how to power it. I know you need a SAS data cable and a SAS controller which can be expensive. But how do I power the SAS hard drive? The standard SATA power cables won't fit.
They should.
These should be less than $10 delivered from ebay. Although make sure you get the correct one for your SAS controller. And make sure it is the correct direction forward break out instead of reverse.
As you can see the standard SATA power doesn't fit
SAS drives use a combined SATA data+power connector. You will need to get an adaptor that breaks it out, or use a hotswap chassis for it.
Exactly this. The SAS connector is designed that way so there is no possibility of someone connecting a SATA connector to a SAS drive.
what you need are cables with sff-8484 connectors such as:
http://www.provantage.com/startech-sas8482p50~7STRT0P3.htm
As said before if you let us know what SAS controller you have we can suggest the proper cabling for you. Note that even if you manage to power the drive you cannot address/controll them without an SAS controller, motherboard SATA controller or a sata add-on card will not suffice.
With all that said, you can make the power and data cable fit by removing the wide edges of the connectors (on the cable NOT the drive). this is only useful if you already have the controller and data cabling, but not the proper cabling; I do not advise this for a permanent solution but only for a temporary data recovery or testing rig.
Yes, but using that cable, you can still only use it with a sas card, not sata ports on the motherboard
∞Velocitymaster∞;1038484656 said:
Hot swap is not an option in my case since I don't have a budget for that. I can get the SAS controller from newegg. So I think this will work
http://www.newegg.com/Product/Product.aspx?Item=N82E16812200786
since my PSU has the standard 4 pin molex
Buy or at least figure out which SAS controller you will buy before picking a cable; there are a few different connectors that controllers can have.
Agreed. The one in the link is not even the most common .
I strongly second what Neb just said. Start with an SAS controller first, then work from there!
so many choices, just a few examples (ebay numbers):
251013687088
310385077167
180837556312
the cable Dan posted works if you already have an SFF-8484 to 7-pin sata fanout cable, it's just a single drive adapter. The cable that patrick pointed you to will directly attach one of the SFF-8484 headers on your card to 4 SAS/SATA drives, with no further adapters needed
should have been more explicit. i have an m1015 with two 4-port sas to sata fanout (forward breakout) cables. 6 of them go to sata drives in the data pool. one goes to an external sata backup drive. the last one goes to a 15k SAS drive used as read cache, so i needed a way to connect to that.
Going from the picture on the HP site and the diagrams in the manual, it's a 8484. The one Patrick suggested should do the trick
P200's have SFF-8484
P400's have SFF-8484
P600's have SFF-8484
P210's have SFF-8087 << MiniSAS
P410's have SFF-8087 << MiniSAS
Yesterday my SAS controller arrived which is the HP Smart Array P400 from ebay and the cables http://www.buy.com/pr/product.aspx?sku=205663955
The controller installed fine with the generic PnP drivers, the cables were able to fit on all ends. I power up the machine and I see one green led light on the hard drive PCB but it's not spinning. I don't hear anything plus no additional storage is detected in windows. The PCB warms up a bit. I did plug everything in right. The 4 pin molex to the PSU. I'm puzzle here
Did you go into the raid controller's BIOS and check the settings? I would expect there to be a BIOS prompt for the RAID controller after post.
There isn't a bios option after the main board bios screen. The card is seated in the my PCI express x16 slot. The board that I have is an Intel DQ67SW
I went in to the motherboard BIOS and is not detecting anything in the x16 slot. The SAS card is warm, and especially the LSI chip on it. But it does detected in windows device manager.
Actually I figure out my computer is not detecting the controller at all. The LSI 1394 OHCI compliant host controller was part of my motherboard. I hope is not DOA
Got it to work, I install the card on an older Pentium D system with first Gen PCI e x16 slot and now I see flashing LED lights on the controller which I never seen before. Plus the hard drive finally spins up. I just need to find XP drivers for this controller.
Did you get a RAID BIOS screen this time?
Negative on that.
But the motherboard bios last a bit longer from cool boot till I hear the SAS hard drive spin up then it passes it. This board is an older Intel board where it has the Pentium 4 logo screen. On Monday I will try something that just pop in my head this evening. Going to remove the card, and get in to the board bios and disable quite boot. Hopefully that way I can see an option to get in to the RAID bios of the controller.
many motherboard bios that have a "quiet" boot option will allow a specific keystroke to drop you back to the normal BIOS/POST screen. Usually when i see boards with this feature the left tab key serves this function. In addition, even if you cannot see the bootstrap messages due to the "silent" boot option, you should still be able to invoke the controller's BIOS with a keystroke; all of the LSI cards i have worked with have used ctrl+i for this.
To me, the issue more sounds like, out of bios memory space, and you need to disable some bios to make things work.
I just installed and FC card that did pretty much the same thing, plug it in, boot, but no bios for it, the os booted but couldn't use the FC card correctly.
Went in and disabled everything I didn't need, nic rom boot, I already had scsi rom disabled and some other things, but that made enough space that the FC bios came online, and everything was happy and it saw the drives.
The problem is the option rom is not working properly. Do 2 things.
Disable everything in the BIOS you arent using. USB3 controllers, additional sata controllers, serial ports, onboard sound, etc.
Check your boot order settings. Make sure your card is listed.
When you boot and controller is initializing press F9 to enter the RBSU or F8 to enter the ORCA.
Manual: http://h20000.www2.hp.com/bc/docs/s...c01608507/c01608507.pdf?jumpid=reg_R1002_USEN
I disable the silent boot which allowed me to see the POST memory count etc... and after that I got to see the controller initialized. I had options to configure the HDD's from there. I also installed the HP array config software which works fine.
Thank everyone for all the help
