New to Overclocking
Darlok
Hey guys.. I just got my E6600 with 2 GB Corsair Ram a P5B-Deluxe ASUS and a eVGA 8800 GTS. I have a 9700 Zalman on it and my cpu idle temp is 32'C. I want to overclock it.. I have it running at 1.4 Volts already and have 3.2 Ghz.. What do i set my CPU frequency and Dram settings to? Do I leave them on auto? Can someone help.. I"m new to overclocking.
Disable C1E, Speedstep and Thermal Control.
Disable ALL SPECTRUM / THROTTLE SETTINGS
Set your PCI Express frequency to 101-105mhz
Set the PCI LOCK or Frequency to 33:33
Set your RAM to the advertised voltage and timings (go to the manufacturer's page or Newegg)
Set your FSB to 401 and your RAM to 802mhz (if you have DDR2 800mhz that is).
Set the CPU voltage to 1.45V
See how that goes!
my computer didn't want to boot up with those settings.. I'm at 1.45 volts at 3.2 on my E6600.. and i have DDR800 Memory
Try and play around the FSB voltage and the MCH Voltage. Up those a bit. Also try taking the CPU voltage to 1.475V
