Hi, I originally wasn't going to OC, but after reading alot of forums for info, people seem to be getting these i7 920's to 3.8+, so I got the bug to try it out.
My specs: i7 920, EVGA x58 sli, 6 gigs GSkill 1333 mhz ram.
I updated to the newest BIOS, and then attempted to OC. I originally used a guide on the EVGA forums that was showing how to OC to 4.2ghz using 1600mhz ram. Being I wasn't going for 4.2 ghz and I don't have 1600mhz RAM, everything didn't translate to what I was doing. Anyway, I went for a 3.2 ghz OC, and changed the CPU host Freq to give me 3.2ghz, my Unicore Freq to I think 17 which gave me 2760 mhz. It was the closest available option to double 1333mhz. Set my Mem Freq to 2:12 which was the option for 1333 and changed my QPI Freq selection to 4.8 GT/s. Well, I blue screened right before windows booted up. So I re-loaded my defaults. I know I just have no clue how to manually set those other settings.
I tried again, this time just changing my CPU host Freq to get 3.5 ghz OC and touched nothing else and left them all on Auto.
Well, it booted w/ a OC freq of 3.5ghz and my DRAM has auto changed to 699mhz. Its running fine, no extra heat generation. I ran Intel Burn test 1.9 for 5 passes at maximum stress and passed. None of the core's temps exceeded 60 degrees. I then tried running 8 instances of Prime 95. I left the room for maybe 40 min and when I returned, the pc had rebooted itself to safe mode giving me windows shut down improperly. I'm curious why this happened, I was under the impression the Intel Burn Test was better and if I couldn't last an hour w/ Prime 95, I should of blue screened immediately w/ the Intel Burn Test.
I ran Intel Burn Test again for 10 passes and passed w/ my temps never exceeding 60 degrees again. So my question is am I unstable?
A couple other question, instead of leaving all my BIOS settings on auto, which should I learn to manually change? or is that necassary?
When I boot up my pc, the initial screen shows my RAM as 1066 and not 1333mhz? Why is that.
Any help, suggestions, references will be appreciated.
Thanks in advance.
Thanks in advance.
