Well, it's been a while (years, in fact) since I've had reason to do an overclock on my system, but I thought that running an E6400 at 3.x GHz sounded like a good idea, so I went out and bought that, a Gigabyte 965P-DS3, 2GB OCZ Platinum Revision 2 (DDR2 800), and a Scythe Ninja (with what turned out to be a broken LGA775 bracket, so I'm running on stock air until Scythe ships me out a replacement part). I know, I know, OCing mostly has to do with luck, and not all setups, even those that are the same, overclock the same way, but I just wanted to hear some advice/suggestions from those who are more wise in the ways of the overclock.
