New to Intel. Help identify this 6600.
Despotes
After reviewing the Conroe oc database I'm still at a loss as to what stepping this chip is.
Here's what's on the chip:
6600 SL9S8
2.40GHZ/4M/1066/06
L631A454
Is the A4 the stepping or the code??
Also--there is a srcatched imprint indicating use from a square fixture(1/4" smaller than the heatspreader). Is this normal?
Thanks
I know, but what's the stepping?
In the oc database A454 seems to indicate the code and almost every chip there has a 6 B2 stepping. Where is my stepping info??
Is the stepping info only available through CPU-Z? Just got this(retail)today and I'm waiting for the 680i to arrive.
Thank you
From where did you bought this cpu?
seems to be a good clocker ")
6600 SL9S8
2.40GHZ/4M/1066/06
L631A454
Thanks
6600 SL9S8
2.40GHZ/4M/1066/06
L631A454
L6 = stepping 6
31 = week 31 - later weeks have generally overclocked better than the first few weeks (week 23-25 had more "duds")
A454 = code , like a batch #.... not really important, though the newer Bxxx seem to be overclocking more
stepping & revision are also available through CPU-Z.
So far ALL RETAIL (&OEM) chips have been Stepping 6 Revision B2.
ONLY the ES's were different.
Thanks for the replies. Much appreciated/
I got this from Newegg. Ordered last week.
My eVGA 680i was just dropped off! We'll see how this cpu does.
So a L631A674 should be a good over clocker?
haven't set it up just yet.
package date is 09/19/06
retail set from DirectCanada.com
You also have a week 31 chip, so thats a fairly recent chip. It will probably overclock well
BUT who knows, it might only hit 2.8Ghz!!!
for the 100,000,000,000th time, its luck of the draw, you don't KNOW until you try it out!!
Your odds are better with more recent chips, but it still doesn't guarantee you anything.
Look at the Conroe database (stickied). The average overclock is around 3.2Ghz + or - 300Mhz roughly. (so 2.9Ghz-3.5Ghz is the most common clocks)
You'll probably end up with about 3.2Ghz, ie: the average overclock.
I just got a week 32 E6600 from newegg last week
The week before that I got an E6400 week 27 from them,
I think they go through more E66s then E64s
Just wondering, I've always been under the impression that chips were limited by heat and voltages and not necessarily "hard" caps?
Even a "dud" should reach 4.0+ with correct cooling, just requiring more of it ...correct?
To a degree.
But SOME chips will just error at a certain speed or higher no matter what.
Obviously, extreme coolin (vapor / liquid nitro) + extreme voltage can bring more out of chips. But the good chips will still do better, the bad chips will still do worse.
IE: a good chip may hit 4.5Ghz(or more!) with that extreme stuff, an average may hit 4Ghz, and a weak one may only hit 3.5Ghz (or less).
My 6600 is maxing around 3.3Ghz maybe a little higher. Core 0 is the weak link.
I'm at 1.45v. Every little increase in speed requires a lot higher v.
Interestingly on this eVGA 680i if I leave the HT Multiplier at the default 5X my system will stop and freeze right before the Intitializing...something data line during boot up. 4X allows me to boot up fine though.
Currently at 367X9 (3.3Ghz) Memory is unlinked running at stock to rule it out as a limiting factor.
I still haven't done any long stability testing though. Just a few hours of dual Prime95, SuperPi, BF2 and 3DMark2k1SE.
I should be happy with a 900Mhz overclock... Before I switched from AMD I kept telling myself that if I can get at least to 3.2 I'll be happy. hehe Now I want at least 3.5! :rolleyes: :D
