New to cooling...suggestions?
maximus1284
I posted this topic in a different forum by mistake, so I'm reposting it here:
...anyway, I'm building a new rig and looking for a moderate to high OC. I want to be able to OC my E6700 up to 3.66 and keep it stable, and maybe try as high as 3.8 or 4 (stable). My goal though is a 1Ghz OC. I want to do this without my CPU, mobo, or any other parts of my PC overheating. I'd like to keep temps at about 65C for the load. I'm not looking for an extreme OC, but something reasonably good
I have a CPU cooler picked out that I'll order, but I worry about other components getting too hot - especially my mobo with this kind of an OC. I've listed my other components, I don't know that a fan for my RAM would be necessary, but a cheap one may help. same with my GPU. I would like to keep it cool at the present, and possibly have some room later to OC it a little. I'm definitely worried about the mobo though, and I'm looking into cooling for the PWM, NB, and SB if necessary
I don't know the first thing about extra cooling options, especially for my mobo. if I can get it done cheaply, then great. I'm not looking for the best of the best, and I'm not trying to max my system and get an extreme OC, so maybe its possible to get a couple parts for good prices. my main goal is to make sure my parts don't overheat and keep my PC stable
this is what I'll be running fairly soon:
Thermaltake Armor Case - comes with 2x 120mm fans and 2x 90mm fans, 3 of which are installed. I'll have to double check to see the size the one that isn't installed, and where the installed ones are located
e6700 core 2 duo - I'm considering the Zalmon 9700 for this, and right now the price isn't too bad. I'll be buying a CPU fan regardless, and it will most likely be this one
eVGA 680i - I hear it comes with a fan, but I'm not sure if this is sufficient. I've read about people buying extra cooling for the PWM, NB, and SB...but I don't know if I'll need it. I may also consider the Abit 680i, but leaning towards the eVGA right now. I know the Abit only comes with the installed copper heatsinks and pipes, but that these tend to get hot
2GB Dominator 8500 RAM - I would like to run it at 4-4-4-12 @ 1066...not sure if thats possible out of the box just yet, but I would like to drop the timings down to 4's, and run atleast at 1066
XFX standard Geforce 8800GTX - this is a heat beast, I probably should get a fan for it if I want to OC it in the future, or run SLI (which I do plan to do much later)
and I'll have 3 Seagate Barracuda HDDs, either the 250 or 320. the case fan should take care of this, I'll have to check
I plan to buy some arctic silver cooling thermal puddy too
If you get the Thermaltake Armour case with the 25cm side fan, that will help cool the motherboard and other components, too; so you won't have to worry too much about buying extra fans.
The armor comes with 2 x 120 blue LED fans and 2 x 80 regular fans. The 2 80's aren't anything special but the 120's are pretty nice. My case has the 25cm side fan. Its actually pretty sweet. Its a lower rpm fan that makes very little noise at all.
There are a couple fan type ram coolers out on the market right now. One is made by OCZ and the other is made by Corsair. I've been thinking about picking one up but just haven't gotten around to it yet.
I'm not sure what your mobo will be like by my NB and SB coolers had some goop on it that I cleaned off and put AS5 onto. I think the SB will be ok but I'd really like to pop a fan on top of the stock NB cooler I'm running or just replace it entirely with a thermaltake cooler/fan setup and just put mini sinks on my chips. Asus runs a combination heatpipe setup for the NB and chips next to the cpu socket.
As far as your core temps go I think I'd bring that down a few notches. 65c is a little warm in my opinion. I'm at 3.2ghz on my setup and I'm at 29c idle/ 40c load. I try to keep my temps below 55c and prefer 50c as my max'd loaded core temp. I have a little room to play with right now if I decide to take it up to 3.6ghz.
excellent...yeah, and I was thinking of going a little cheaper on the CPU cooling as well, the Scythe SCNJ-1100P is at a pretty good price and seems to work really well. that should get me up to 3.66Ghz without heat problems
I'm not sure that my Armor has that 25cm side fan...it sounds like it should, I'll double check later
what kind of fans should I be looking at for NB, SB, and PWM? I've been looking at newegg and it doesn't seem like they have a huge selection, though I found a couple products that seem decent for NB/SB, but I can't find anything for PWM. I think the eVGA comes with a fan for the PWM, so thats probably not a big deal
newegg has a couple memory fans, but they were priced at like $15+...I'm not sure I'll need one with the dominator heatsinks, but are others available at lower prices? and do I need to buy one for each stick? (that would seem a little ridiculous...)
I may take a "wait-and-see" approach with cooling, as I won't really know my temps until I get everything ordered and installed. I'm still at least a couple weeks away from installation
if you are looking for the best air cooler, either the scythe infinity or the tuniq tower, both monsters, the zalman has gotten good reviews too but just slightly higher temps, good review currently at anandtech front page...
i currently have the infinity installed with two fans in push/pull, my e6700 is oc from 2.66 to 3.66 with 40°/58°, runs stable under p95 overnight
Yep, agree! The advantage of the Scyth Infinity is (I just discovered) that yo can mount two 12 cm on each side.
Another advantage is that the cooling ribs are not packed too tightly so that cooling wind can remain it's speed when passing the surface of those ribs. And faster air cools better than slower moving air.
This all seems pretty straight forward but I see a lottof too tight packed heatsinks out there which slow down the airstream almost completely.
With the two fans one sucking air and the other blowing it in you get realy extreem aircooling.
My specs fully underlines this statement:
3,51 GHz - CPU 1,4125v In Bios setting - max. temp CPU load: 43 Celsius Idle: 23 Celsius in Probe II
Fully stable after 16 min ORTHOS
I am astonished by the low temps I have now even at 3,51 GHz and 1,41 BIOS Volts.
Another advantage is you can use two very silent 12 cm running at a stable 1000 RPM makes your case even more silent.
Biggest sound bugger is the fan of my XT1950XT I am gonna remove that bugger (How lovely this GPU looks anyways) and replace it for two silent 8 cm fans.
Wow, Youri Carma; i think i might just have to copy you! :p
What CFM are those fans? Also, how are you mounting those fans? It looks like you're using swingy metal bracket things on the top (the top of the picture), but i can't see anything else supporting them...
These metal clips where in the Scyth package but only for one fan....but I had to use two so I just mounted the upper clips and used a little islolated electric wire to keep them on the heatsink.
I am very curious also about the Tuniq but when I had a look again at it..and to be realy honest......I think I cracked it.
Cause the wind velocities I can generate this way the Tuniq with only one fan is not able to.
Thats why I widened the hole in the back of the Acrylic Case...cause it blows like hell the back out there!
Cool wind wants to suck everywhere the Scyth hasn't been covered by fan.....nearly freezing in there Lol ;-)
I seriously even got a little worried if my PSUFan was still able to suck enough cool air.
Ichbinleise.de Blue Led Fan specs:
- 57,2m³/h (33,6cfm)
- 19dB(A)
- 1000 RPM
- Lasting at least: 50000houers
- Boldbaring
I think the 12 cm Acrylic Sharkoon Led Edition (also the normal) Silent Eagle 1000 are very good.
Specs:
64 m³/h
21 dB(A)
1000 t/min
The Scythe Infinity definitely seems the most versatile HSF in its price range, considering this amazing mod. Do you think you could post a couple more pictures of your cooler, i'd like to see how it's fitted exactly. How are the clips attached to the fan? One more thing, with the clips on the top of the fans, are they just hanging there; i mean, are they attached at the bottom at all?
Thank you for your help. ;)
I replied in your other thread...
I'm sorry...are you sure it was mine you replied to?
anyway, I'm probably going to go for a Scythe Ninja or Infinity, or maybe a Tuniq Tower 120 or Zalman 9500...I know thats a long list, lol, but it really depends on my budget at the time and the feedback. all are priced fairly decently...
I'm actually now considering the E6600 because I've seen people getting it as high as 3.6 and higher! but I don't think I can achieve that with air cooling...I'm really considering getting it now and set an OC goal of 3.4
anyway, what do you guys suggest for eVGA mobo cooling with about a 400Mhz FSB OC? I've asked around a little and I'm not sure I'll need it. I've tried to search the forum, but I'm actually having a hard time finding what kind of mobo temps OCers are getting
I guess 400Mhz is a little higher of an OC than what I thought, I didn't realize it would get an E6700 up to 4Ghz! are people able to do this with stability? craziness!
are the 2 fans a custom mod you did?
my armor doesn't have that 25cm side fan...was this also a custom mod?
dang that stinks
anyway, think I may go with the e6600. I want to get it to 3.4, possibly 3.6. I found a zalman 9500 for $49.99, tuniq tower 120 ~$54, and the scythe infinity for about $39-$45. I think I'll probably go with the scythe infinity
as for mobo cooling...hopefully my case ventilation will help a lot (I bought it cause it has 4 fans...), as well as the stock eVGA cooler that comes with...I'm still going to try and get my dominator 8500's to run at 4-4-4-12 and 1066Mhz...I'll take a wait and see approach for mobo/RAM cooling, and I guess I can always increase how fast my fans are moving
Youri Carma: what kind of mobo temps are you getting? do you have additional cooling for that? how much was that 12cm fan for the Scythe? I don't need one with LEDs, but those do look pretty sweet
I found mounting brackets, "Perfect for Infinity CPU cooler dual fan solution (in/in, in/out)" lol
http://www.jab-tech.com/product.php?productid=3720
also...I plan to buy arctic thermal paste, but do I need an arcticlean surface cleaning kit?
Arctic Silver cleaning things really aren't needed, some isopropyl alcohol will work just fine. You shouldn't even need to clean anything anyway, since it will all be new, right?
yeah, but I've read about people removing the old paste on their mobos and putting on the the new paste
Not needed. Just get some 99% ISO alcohol if you want to re-do any of the thermal paste on the motherboard.
Replacing the NB HSF paste is also fairly dangerous too... It's easy to crack the NB.
hmm I wonder if I can use ANY regular 12cm case fan with that mounting bracket for the scythe in/out configuration or just scythe fans...I could get some really cheap fans with really nice airflow and I could use the stock fan as my "out" fan...I don't imagine the out fan would need to be THAT good, but I wonder if huge airflow would be overkill for the scythe infinity...
dang that stinks
Another Mobo Cooling TIP: Remove the cap (with the Asus logo) from the passive NB heatsink.
These clips you have in the link are exactly the clips I got with the Scyth, like I said before, only two of them. I only used these clips to attach the fans at the top side an in fact gravity does the rest. But to be completely sure I added an extra copperwire on the bottomside.
My mobo temps are around 36-37 so much higher than my idle cpu temp around 20-25.
I discovered that because of the Heatsink on the NB of the P5B-DL, if I push the sucking side (on the picture you are looking towards the blowing side) fan more direction mobo my mobo temps can drop 5 celsius easely. In fact I bought a 14 cm fan so I can cool the NB sink and mobo as well.
14 cm
93 m³/h (54,7 cfm)
19,6 dB(A)
1000 t/min (±10%)
I also hear some postive reactions on the Arctic Cooling Freezer 7 Pro (On the picture the AMD 64 s939 variant) - Socket 775. I think it's a realy good value for money product.
Review: CONCLUSION; about the Arctic Freezer Pro
awesome! so I can pretty much use ANY 12cm fan with those clips/heatsink? would you say there is limit to how high someone should go with airflow? theoretically, the more airflow the cooler...but with it being set right on a heatsink, there has to be some limit of how much air can much through those coils
where do you have your aerocool placed?
In fact I havn't placed my Aerocool yet cause it can't be mounted with thos iron clips cause the Aerocool is thinner than any other standard 12 cm fan.
They did this so there is extra room for the 14cm to 12cm convertorplate.
So I have to think of a other way of mounting the 14 cm on the sukking side.
Work in progress so to speak.
With what you want to achieve, there is no need to spend extra $$$ to cool your mobo and rams..... Just make sure you have good airflow and the stock nb cooler should be fine.... I suggest taking off the nb/sb heatpipes, clean ,reapply thermal paste and reinstall it... This procedure is not so you can use better paste but to make sure that the HS are installed and seated properly.... In my Commando, only half of NB die had thermal paste on it, the SB wasnt much better....
As for CPU cooling, the Tuniq is the best cooler you can buy.... but the performance of all these high end cooler are so close taht I doubt youll get a better overclock from choosing one from the other..... I have a Thermalright Ultra 120 and I couldnt be happier... I did try using 2 120mm but at full load my temp was only lower by 2c so Im back to one fan...I dont use a case so the results might be different in a cased computer....
3600mhz in a E6600 should be a breeze..... I run mine at 3800mhz 24/7 and its very relaxed at that speed.....
I almost am tempted to buy the Tuniq just do do some test comparison but the way the heatsink s775 is attached holds me as well as other things to do.
But the Tuniq also has it's cons:
Installation was a pain. (Also with the Scyth Infinity)
It's Huge. (And I say It's too Big so in some cases it doesn't even fit)NOT TRUE: Scyth:Height 16 cm Tuniq Tower: 15.5 cm
It's Heavy. (Scyth isn't heavy I can assure you)NOT TRUE Scyth: Weight: 830g (WITHOUT FAN) Tuniq Tower Weight: 800g (WITHOUT FAN)
Couldn't outperform a heatsink half it's size.
http://www.ocia.net/reviews/tuniq/page6.shtml
But in this Scyth Review: Conclusion they also think it's heavy.
I did some weight measuring on fans myself and these are the results:
Weight 130g 12 cm Scyth Infinity
Weight 135g 12 cm Sharkoon Slinet Eagle 1000 (non ledfan)
Weight 115g 12 cm Coolermaster Acrylic Led fan
So in fact Luihed you are completely right the weight of the Scyth Infinity is 960g - 130g = 830g which makes the Scyth even with the Tuniq Tower in weight comparison ...I was proved wrong again by the facts here.
So in fact indeed both fans are very good especially when on the Tuniq Tower you also can use any 12 cm fan.....only disadvantage is that you use one instead of two 12 cm fans on the Scyth.
Still I would like to chalange the Tuniq cause I realy believe that the two working together (sucking blowing ) fans running each 1000RPM does do the magic!
In fact you don't need another fan for case OUT blowing only some small to improve the inward airstream. But relative hot air moving fast also brings extra cooling.
Both have mounting problems by the way.
dang and I thought the infinity was smaller....I hate the idea of having a huge ass cpu cooler hanging off the side of my mobo...I don't know how these things don't snap off
luihed: which cpu cooler did you try 2 fans with?
I guess it depends on what you want out of a cooler... That test on the review was on a cpu running at default voltage ( i think ) of 1.4v, at that voltage, you might as well save your money and use teh stock HSF lol..... If youre going for all out performance, I think teh tuniq will eat XP-90... put 2 x 120mm on the tuniq, crank up the vcore to 1.75v on your Conroe and see how high she goes...... I cant even think of trying that with the XP-90, I have no where to install the 2 fans......
There is a reason why the Tuniq is the cooler of choice by the top overclockers on air........ I dont have a tuniq BTW....
Maximus, I did it on my Ultra 120... I was using a 120cfm fan intake and I think the outtake is around a 90cfm fan.....Temp IIRC went from 70c to 68c or something like that, again my setup is very different than yours so you might get alot better results than I did..... 24/7 I only have one fan running and its set at minimum
These rams dont get hot at all so save your money... if you want to cool your rams, the best cooler is still taking off the heatspreaders and running them naked....
I think 1,4v is not realy a deafault temp at least not for the E6600 my findings: 3,33 GHz - 1,3500v In BIOS setting and 3,51 GHz - 1,4125v In Bios setting.
Two fans put at a minimum is even better cause you won't hear more noise espescially if you put them on exact the same RPM.
I also think that the stock Intel heatsink is well made with a complete copper inside which is not the cheapest way to produce a heatsink.
This copper inside goes al the way to the top of the allumium coolribs as you can see on the picture yourself.
Also I heard ver respectable results with the standard heatsink.
I also think reinstalling the NB Heatsink is a good idea (with Arctic Silver 5 or GeiL Copper) also like removing the heatsinks cap, it has no use at all.
You probably have your vcore set at Auto so the mobo increases your vcore as needed....
As for reinstalling the NB hsf, Ive done it to every mobo that Ive bought the last 5 years and Ive yet to opeen one up and say " hey thats not bad".... For $200+ mobo, Id expect better quality, but it only takes 10 mins to do so its no big deal....
Which Vcore are you exactly talking about?
I am talking about manual Vcore setting in the BIOS of the CPU!
Are you sur you are talking about the E6600 Conroe?
Lol... I was actually talking about the AMD 3200+ in the review you posted... I just breeze through the review and for some reason I thought they only tested it at 1.4v lol...me bad...
You got me all confused with what you said here.... I still have no clue as to what youre saying here....
OK I'll be mister precise with you:
BIOS SETTINGS E6600 PB5-DL WIFI Edition
AI Tuning [manual]
CPU Freq [389]
DRA freq [DDR2-1167 MHz]
PCI Express freq [AUTO}
PCI Clock Synchronisation Mode [AUTO}
Spread Spectrum [AUTO]
Memory Voltage [2.30 V]
CPU VCore Voltage [1.4125 V] Read my lips....
FSB Terminator Voltage [1.450 V]
NB VCORE [1.45V]
SB VCore (Sata,DCIE) [AUTO]
ICH Chipset Voltage [AUTO]
BIOS HARDWAREMONITOR
CPU Temp: [33]
MB Temp: [35]
CPU Fanspeed [1016]
CPU Q-Fan Control [Enabled]
CPU Fan Profile [Performance Mode]
VCore Voltage [1.368 V]
3,3 Voltage [3.312 V]
5V Voltage [5.120 V]
12V Voltage [12.038 V]
Frequency: 3.516 GHz
FSB Speed: 1556 MHz
Cache L1 32 KB
Cache L2 4096 KB
Ratio Status Unlocked (Max: 09, min:06)
Ratio Actual Value: 9
CPUID: 6F6
So, no way 1,4v is a default CPU vCore figure unless you call 3,5 GHz the default CPU frequency settings LOL.
Well maybe I should consider it default 3,5 GHz :)
AI Tuning [manual]
CPU Freq [389]
CPU VCore Voltage [1.4500 V] Read my lips....
NB VCORE [1.45V]
CPU Temp: [33]
MB Temp: [35]
CPU Fanspeed [1016]
FSB Speed: 1556 MHz
Cache L1 32 KB
Cache L2 4096 KB
CPUID: 6F6
http://dictionary.reference.com/browse/default
Yep, "when the user or programmer specifies no overriding value or action."
So in fact I think there is some other communication error cause my default is 2,4 GHz not 3,5 Ghz.????
So again 1,4125v is not a default value.
I run at the not default 3,33 GHz - CPU VCore 1,3500v In BIOS setting.
I don't know what you exactly mean with high CFM for Infinity?
The Infinity fan in the Scyth Infinity package is a good one...it is a silent fan.
I don't know what the CFM is of this infinity fan but I am sure it is enough.
I use two Ichbinleise.de Blue Led fans 57,2m³/h (33,6cfm), 19dB(A), 1000 RPM, Boldbaring.
I think the 12 cm Acrylic Sharkoon Led Edition (also the normal) Silent Eagle 1000, 64 m³/h, 21 dB(A), 1000 t/min are also very efficient fans.
I think if you let two silent 12 cm fans run at around 1000 rpm cooling wil always be sufficient and you have not too much noise with any fan.
With the use of two fans you don't need the top CFM fans cause it wil only increase the noise level. You can however use a hardware fancontroller to get your fans running in pair rpm.
I think you understood...basically what I was asking was should I go with a fan with a higher CFM?
I believe the infinity has about 46 CFM, so clearly there is the potential to get something higher like 70+ but at the expense of noise. however, since these are mounted directly on the heatsink there has to be some point where the CFM to cooling ratios just aren't that efficient. I believe there is a point where more CFMs probably wouldn't make much difference for the heatsink...I don't plan to test this, but I was curious if you had any thoughts on this
on a side note, I'm starting to wonder if an in/out config could "steal" air from the case intake fan, in effect allowing less air to blow past the rest of the mobo, but maybe I'm just over analyzing lol. I imagine you have your case set up this way. the arrows represt airflow:
<-------case exhaust fan<------mobo/cpu cooler<----case intake fan<-----
Just get the highest cfm fan you can get a hold off and get a something to control the speed....
Well Fans are not the most expensive and it is relative easy to change the fans on the Scyth so maybe I'll make a test later with two max CFM Fans disgarding the noise production.
But like I said with two fans working together on 1000 rpm you don't realy need that.
I think that is diffirent with the Scyth cause the cooling rips are wide apart so that they wind doesn't get much slowed down.
But to be sure I am also gonna test this. First go on only one fan and start ORTHOS CPU stresstest after 5 min I reach a CPU temp of 42 Celsius.
Than after these 5 min I connected the second fan...the temp drops with only 2 degrees celsius from 42 to 40 Celsius....leave it for another 5 min with ORTHOS on.
Than after 10 min ORTHOS disconnect the second fan again...the temp reaches 42 Celsius again.
So in fact also here luihed has it completely right it doesn't make that incredible diffirence which I claimed....so again I am wrong.
Also in IDLE exactly those 2 Celsius diffirence from 21 to 23 celsius.
Only advantage which remains is that you already have a good casecooler as well blowing out the back of your case but that's realy minor.
It looks Cool thats all...and you have something to talk about ;).
To be complete this test was done on the E6600 with the P5B-DL WIFI on 3,51 GHZ (Multiplier 9) CPU vCORE 1.4125v in BIOS setting. Scyth Infinity cooler with one and two Acrylic Ichbinleise fans (Which is German for I-am-quiet-fan) 57,2m&#179;/h (33,6cfm), 19dB(A), 1000 RPM, Boldbearing.
It is however known that two exactly the same machines or fans running at the same speed make almost as much noise as one machine or fan. Even with three or four fans the noise will not increase three or four times...again the must run the same rpm.
A Silverstone FM121 fan is a 110 CFM fan, very powerful but it also come with a fan controller so you get the best of both worlds. I got 2 of them in my PC, 1 on my Thermalright SI-128 and the other as a intake fan. I ajusted the speeds until it's fast enough to get the best cooling while keeping the noise to a minimum.
wow thats surprising and dissapointing. there has to be some advantage to 2 fans though, like a cooler mobo...oh well, I guess I won't worry about fans then. how fast were the fans spinning? I wonder if putting them at 70&#37; or 100% would matter. how does the inifinity performs with no fans?
now I think I'll give the tuniq tower 120 more consideration since 2 fans in the infinity doesn't make that much difference
