New to building, have a question.
StickClicks5
I am a little new to computer building and had a few questions about the mobo, before I go to school X.X
I plan on getting this mobo with the AMD Athlon 64 2x 4200+ duel core CPU. My concern is that the motherbored will not pick up the proccessor since it came out after the mobo did, at least that is what has happened to a few people. How easy is it to update the bios om the mobo? Can you do it if you have no CPU?? and is there a guide to this some where. Thanks for the help in advance, gota go or Ill be late.!
Updating BIOS on ASUS boards is simple, but you must have a CPU to do it. The only way you could update the bios without a CPU is to install a new BIOS chip in the motherboard.
Many of the boards currently being produced have later BIOSs on them which will recognize dual-core processors.
Even if it doesn't, you should still be able to boot from a floppy disk and perform the flash to a newer BIOS.
dude go on and get the Abit AN8 32x mobo and save urself some trouble.. it automaticall recognized X2 processors and u need to get a 3800+x2 because they are a better deal if u wanna oc....
Im not planning on overclocking. As I said, this is my first build, and I dont think I want to risk doing something wrong and loesing 500 bucks. Also, the mobo recomended in the post above doesnt have enough PCI slots for me, and 180 is a bit to expensive.
that asus a8n sli is a very good board.the last one i put in a rig a few weeks ago came with a bios that recognised the 3800 x2 i put in it.i bought it from newegg so they most likely have the newest stock and latest bios installations that asus is building them with.i believe it had 1010 if i remember correctly.ive now done 4 custom builds with that board and all of them went perfectly..as time goes by and if you get the bug it also o/clocks well doing moderate o/clocking.it also likes corsair xms c2 ram.it runs at 1T up to about 340 htt 1 to 1 with the cpu.im running my xms ram 1 to 1 at 250 mhz 1T 2.5,3,3,7 and have the htt multiplier at 4x.
I used 2 nvidia 6800 video cards for the customer as he requested them and the system performed flawless.he used a 3800 x2 o/clocked to 2.4 with cpu voltage at 1.39v and ram voltage at 2.7v.i also installed a zalman heatsink on the chipset and put a 40x10mm led fan on it after cutting the tall finds off flush with the shorter fins and the chipset temps never went over 42c..running the net it was at 36c or so.cleared both video cards by a mile.all in all a very nice system and no issues at all.i run the a8n-e board as im not a gamer and ill tell you these a8n series boards are great boards.i wouldnt trade mine for any other board as this is my 4th ultra board.its so stable o/clocked and running cool and quiet,all at 2500mhz,1 to 1 with ram and cool temps.cant beat it.id have to look at the asus lineup if i was looking for another board to install.my first dfi board the exert killed my cpu at stock settings on a cold boot,so thats my last dfi board.should have never gone away from this asus board....good luck
As long as that board has 'EZ-Flash' (check manual, I think it does) just have a floppy ready with the new BIOS named whatever the manual says to name it (probably A8N-SLI.ROM). Even if the CPU is unrecognized with the old BIOS, just hit Alt+F2 when starting, and it will update.
Yea the board has ezflash...
but I would go with either a Deluxe or a Premium....not just the plain one...yucky...
