New to building a WC Setup
Ok I had a post out here but it got deleted in the system so sorry if reposting. I think I'm going to build a system with all swiftech products useing the H120 kit as a base and adding a 2nd Rad. I have an Antech p160 case but might buy a 900. one Rad will be internal mounted on the back 120mm fan mount and the seccond will use the ports and be mounted useing the Radbox that comes with the kit. the reason for 2 Rads is one for the CPU and then taken out to the 2nd rad and then back to my 8800GTS useing the MCW60R waterblock and useing their heatsink kit for it also. I've used the coolermaster assembled kits in the past so this is my first time building a WC setup. Any Ideas anyone?
