New system & upgrade - what do you think?
msny
Build like every 3 to 5 years. New system will be for TV, video, lite to moderate
gaming rig. This replaces my #2 system in sig which I will sell off. Not an avid
OCer. Long time [ H ] member so I trust you guys views. If you see anything that
may not work together or is deficient to the rest of the system please let me know,
NewEgg - new build
LIAN LI PC-60APLUSII Silver Aluminum ATX Mid Tower Computer Case - Retail
http://www.newegg.com/product/product.asp?item=N82E16811112069
ASUS P5B-E LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
http://www.newegg.com/product/product.asp?item=N82E16813131070
BFG Tech BFGR88320GTSOCE GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 OC HDCP Video Card - Retail
http://www.newegg.com/product/product.asp?item=N82E16814143086
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply 100 - 240 V UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick - Retail
http://www.newegg.com/product/product.asp?item=N82E16817139001
Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor - Retail
http://www.newegg.com/product/product.asp?item=N82E16819115003
CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/product/product.asp?item=N82E16820145168
(2 of these)
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/product/product.asp?item=N82E16822144701
LITE-ON 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 40X CD-ROM IDE DVD Burner included extra White bezel - Retail
http://www.newegg.com/product/product.asp?item=N82E16827106050
I will add to this my current Hauppenge USB MPEG-2 video card and
Dell 24" monitor. Vista Ultimate OEM for this.
Not sure on mouse or keboard, open for ideas but may keep Saitek and
MS wireless.
NewEgg - upgrade of Shuttle SN25P - will be secondary rig that wife uses
for lite gaming, blogging and general surfing. I use mainly for programming
from my work. System #1 in sig.
Replace x800xl with
My concern is 2 fold here
1) will it fit ?
2) will the 300w PS be ok (they say shuttle PS's are rated high?) dunno
Replace 1 gig memory with 2 gig Crucial PC3200 on the cheap.
Will stay with WindXP because I have .NET programming tools from work on this machine
that won't work with Vista. Vista maybe in 6 months.
Same Sony LCD and keep second Saitek keyboard. Has old Logitech MX700 mouse
I'd like to replace.
Thanks!
I do not like Corsair memory(personal preference).
Case is decent.
Never looked at Cosair PSU's before ,will look at them.
Can not go wrong with Asus.
BFG makes killer cards I agree.
On the Proccesor you should get the 1.8 version of chip.You will save money and it is easily oced tobeyond the 2.4 mark on stock air cooling.
I also use Lite-On roms in all my builds they rock for cheap.
Hard drives nowadays are all about the same as long as speed matches(exp.seagate 7200rpm and the one you choose , really about the same.No brand name HD is lacking behind any of the restas long as specs are similar.
I am upgrading from a x800GTO to 8800 series
Your component list looks good ,I see no conflicts of compnents or space in case mentioned.
change the 320mb GTS in youre rig to a 640. worth the money considering the extra 320mb is needed at the high AA levels the GTS gives you :)
change the case to a PC-7B Plus II :) much better case
Case is decent.
you didnt even READ his post... just commented on the specs... he doesnt want to overclock...
I've stuggled with case selection. I want a small case but not to small.
I looked at the PC-7B Plus II also, do you have this one or both?
Why is it better then the PC-60APLUSII do you think?
I choose the PC-60 only because it had a removeable MB tray and the PC-7A(B) did not.
Your point is well taken on the 640 GTS, but I'm not so sure after reading the
hardocp review. Depends on the price difference I guess.
Thanks
Thanks
the PC-7B plus II has all 120mm fans, so more airflow, with less noise :p that, and its black :p theres also a silver verison if you prefer that :p
the 640MB GTS is the 100 way to go on a new system IMO, youre shelling out that much on it, an extra 70 for 320MB of vram to increase the level in which you can run AA and memory hungry effects is worth it to me IMO, the 320mb is the on the cheap, high performance DX10 right now i think...
The PC-60APlusII has 120mm fans as well (front intake and rear exhaust, just like the PC-7A). On top of the 2x 120mm fans, it has an 80mm side fan. The removable motherboard tray and the 80mm sidefan are the only differences between the PC-7A and the PC-60A Plus II, that I can tell. The old PC-60's use 80mm fans all around. I have both the old PC-7 and old PC-60 (they didnt have models that use 120mm fans back then), and I'd suggest goin with one that has a removable mobo tray. However, note that it vibrates... so use some foam or something to keep it from vibrating once slid into place (maybe they've fixed this now? hehe).
Everything else looks good, except for those dominators. There really is no need for such expensive ram since you dont plan on overclocking. Go for some cheaper sticks. They had some XMS sticks for under $175 (2gb ddr2-800) before, but they got sold out. Look for similar priced sticks. Stock settings with that CPU are 9 * 266 = 2.4Ghz, which needs DDR2-533... so dont drift too far from the pricepoint of 533 sticks, since you won't need their speed until after you decide to OC.
And if you decide to OC, you most likely cant go past 400Mhz anyhow, since 9*400=3.6Ghz (DDR2-800), which is likely the limit on good air cooling.
nah, the PC-60APII uses a rear and top 80MM fan, where as the PC-7 uses a rear 120 and no top :) it has a front 120 and side 120 and i dont really find removeable mobo trays of any use in cases like the PC-7 that arent too cramped anyways :p
and as to the memory thing, it uses multipliers to ensure the ram runs as high as possible :)
My bad, I must be on crack. I could have sworn I was lookin at a Lian-Li with 120mm front and rear fans :confused: Oh wellz, I agree, the 120mm fans would be best for quiet computing/max airflow.
I find removable mobo trays make it easier to install the mobo, especially in a cramped case, hehe.
i do too, but Lian Li's are far from cramped :p theyre a wonder to work on...
Well I'm still on the fence as far as the case goes.
I really want a removeable tray because I do like to tinker
somewhat.
As far as the ram goes can anyone reccomend any other then the
Dominators that goes well with this board?
I want really good ram so I'll have to think about choosing something
other then Corsair. I've used Crucial before but there 2 gig kits run
sightly more then the dominator.
I may spring for a 8800 GTS 640 removing the 2nd WD 250gig drive.
Since the price difference is about the same as that drive.
I can get that later. Right now this system is around $1700 buks and
that is close to my limit else the wife will take me to the wood shed.
This was my tax refund.
I found this to replace the Corsair Dominator memory.
Never used it before, better priced. Any good?
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
That link is to the dominators. The G.Skills are good, even though I'm not sure which one you're looking at. The HZ sticks are their best, but the PK and HK sticks are good, too. I'd go with the PK sticks, since they're the cheapest and would have no need to run them faster than 400Mhz with an E6600.
Whoops my bad copy/paste skills sometimes need help
Here is the gSkill link
http://www.newegg.com/product/product.asp?item=N82E16820231098
What do you think?
I'm using those right now. They reached 450 with 2.2V, but I'm running them at stock speed, 400 with 1.8v. They're good budget sticks. If you want tighter timings, the PK sticks are good, too. My friend ordered these 2GBNQ sticks, too, but his could only reach 431Mhz :(
Got a link to the PK sticks you mentioned? Don't see that in
the specs on NewEgg. I prefer tighter timings of course even w/o
an OC.
I'm also going to go with the 8800 GTS 640mb RAM instead of the
320mb for the video card.
RAM is my only decision now, then Im ready to order.
Any of these would be good:
$185 - Patriot eXtreme Performance 2GB (2x1GB) DDR2-800 4-4-4-12 PDC22G6400LLK ($235 - $50MIR)
$190 - G.Skill 2GB (2x1GB) DDR2-800 4-4-4-12 F2-6400CL4D-2GBPK
$190 - Super Talent 2GB (2x1GB) 4-4-3-8 DDR2-800 T800UX2GC4 ($210 - $20 MIR)
$200 - G.Skill 2GB (2x1GB) DDR2-800 4-4-3-5 F2-6400CL4D-2GBHK
Found a PDF chart over at the G.Skill website.
Appreicate your follow ups, very helpfull.
IF anyone should care....
I purchased this today from Newegg with these following changes from my first post
REVISED
Motherboard
Intel BOXD975XBX2KR LGA 775 Intel 975X ATX Intel Motherboard - Retail
Bad Axe 2
http://www.newegg.com/product/product.asp?item=N82E16813121059
I was very torn between the Bad Axe 2 and the Asus P5B-E, as I'm a longtime
ASUS user. But, in the end the Bad Axe 2 I think would have more stability.
EVGA 320-P2-N811-AR GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Video Card - Retail
http://www.newegg.com/product/product.asp?item=N82E16814130082
I wanted a 640meg card, but after choosing the more expensive MB, I had to cut
my total price somwhere....and it was with the 320mb version
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/product/product.asp?item=N82E16820145034
I wanted the G.Skill HK, but they went out of stock and I didn't want to wait.
I've always used Corsair in the past so I'm satisified. I'm using G. Skill
in my Shuttle and I'm happy with it there so far.
The balance of my system remains the same from my first post.
more stable? uhm... ok. i've built several systems with the p5b-e... none of them have stability issues. you would have gotten much better performance from a 640mb vidcard than a 975x chipset, lol. oh wellz. have fun with your new rig!
thats rams great. got it in my system. ive got 850mhz out of it on norm volts :)
Well, I really wanted the Bad Axe 2 feature set. I'm not dissing the P5B-E, it's a great board.
I flipped a coin on this decision.
My thinking is that when and if we see ATI do there R600 thing I want to upgrade the video again....but later.
(video forum has some news now)
That made me think I should not invest to heavily in a 8800 at this point. I usually do a refresh
in a year or so anyways. So, this card will be a stopgap until then.
I should mention that I went with the OC version reviewed here
http://enthusiast.hardocp.com/article.html?art=MTI5MywxLCxoZW50aHVzaWFzdA==
For me gaming does not have to have the BEST settings, I'm sure this card will come close enough.
