New System, take a peek...
CoolEthan
Cooling
Swiftech MCW5000-P for CPU $48.95
http://www.coolerguys.com/productsl...?categoryid=175
Swiftech MCW50 for Video Card $37.95
Enheim 1048 $59.95
http://www.premiumaquatics.com/Merc...tore_Code=PA&Ca tegory_Code=Eheim
Black ICE Extreme $52
http://www.dangerden.com/mall/Radiators/hwlabs.asp
½” Danger Den UV Tubing-blue $2.25/ft x 6ft
http://www.dangerden.com/mall/Misc_...ubing_clamp.asp
Resevoir $24.99
http://store.yahoo.com/directron/bayres.html
Motherboard
Abit IC7-MAX3 $200
Fry’s Electronics
http://www.abit-usa.com/products/mb...ies=1&model=130
Video Card
ATI Radeon 9800pro $249
http://www.newegg.com/app/ViewProdu...-161-109&depa=1
CPU
Pentium 4 northwood , 3.0ghz, 800mhz fsb $229
http://www.newegg.com/app/ViewProdu...-116-156&depa=1
Hard Drives
WD Raptor 36.7GB, 10k rpm, sata $119 x 2 (raid)
http://www.newegg.com/app/viewProdu...-144-200&depa=1
RAM
OCZ Enhanced 1GB PC3700 $269 (was told that this would work even though the board only calls for ddr400 at the most, correct me if this wont work)
http://www.newegg.com/app/ViewProdu...-146-964&depa=1
Case
Aspire X-Dreamer II Mid-Tower Case $65.00
http://www.directron.com/dreamerii.html
Power Supply
Using stock with case for now
So what do you guys think, this is a gaming/overclocking rig, if youve seen prices cheaper than what ive stated here let me know...
Your parts links are all dead.
Depending on what ATi 9800 Pro you're looking at, there are cheaper ones. The Sapphire 9800 Pro is $210 or so.
I'm sure djnes will chime in on OCZ's spotty record and shit customer service and practices.
And I don't see the merit of RAID 0 raptors, but that's just me.
I am convinced that anyone dumb enough to still consider supporting a company like OCZ is behind help anyway.
Also, Raptors in RAID0 is a very nice addition. One single Raptor is not worth the cost and loss of capacity. 2 in RAID0 however, is very nice: See sig.
the OCZ was a recommendation by somebody else, ive never heard of them, im thinking more towards crucial or kingston
I'd go with corsair or kingston. Crucial doesn't belong in overclocking systems.
I'll second that, limited to about a 190fsb cuz i stupidly forgot to get pc3200 (crucial that is) :(
Two things:
1. If you're going to OC, why get a 3.0 when you can get a 2.4 and OC the hell out of it?
2. You need to get a better PSU that what is including w/ Aspire cases. $50 will go far with Fortron, Sparkle, Enlight, TTGI, or Superflower PSU.
The 36 gigers have firmware that is optimized for enterprise environments. You can go two Seagates, two WD or Two Hittachi SATA 80 gigers all for under 90 each and for the purposes of desktop use they all will match or surpase the 36 gig raptors for real world performance in a raid 0 array. The 74 gigers are a different story.They are also optimized for the desktop and are unrivaled in a raid 0 array as it relates to desk top use as well as price performance ratio when pitted against even SCSSI arays
Originally posted by Vertigo Acid
Two things:
Why even bother with a 2.4c when for the same price or almost the same price you could get a 2.8c or 2.6c.
$200 is alot for a motherboard, newegg sells MAXIII for less than fry's try there.
As for the Raptors, they're pretty much a waste for desktop use. I've owned two in a RAID 0 and they weren't much faster if any faster than my normal 120gb hard drive. Unless you're going to be running a server or doing some major video editing, they just aren't worth the cost.
For that system I'd suggest getting one of the Sapphire 9800 pro 256mb cards since they're just 9800 XTs with a pro bios and they perform well even stock (they've got the shiny HSF).
Also go with Corsair, Kingston or Mushkin RAM. Crucial is awesome ram, but not good for overclocking.
