Hey guys, I've been out of the PC gaming world and hardware world for a few years now and quite a bit has changed it seems. I've got an old gaming PC that no longer runs (motherboard is dying) and I am looking to upgrade to CPU, Memory, Motherboard, Hard drive and video card. The old setup was as follows:
AMD 6000+
DFI Lanparty 590SLI
2x 8800GTS's
4GB of memory
4x 250GB Hard drives in Raid 0
Now I am looking at:
Intel i5-2500k
Asus Sabertooth P67
Samsung 830 Series 64GB SSD
Corsair Vengeance 8GB(2x4GB) 1866
Now I am still unsure on the video card. I'm looking for something in the $200-$220 range. I may just settle for a 6950, or continue to use my 8800GTS's for a little while longer.
I plan on casually gaming with the PC, a little BF3 now and then probably Diablo 3 if it ever comes out. I currently use a 14" Dell Laptop for everything and it's getting old using the touchpad and such. Is there anything you would change with my setup? Any video card recommendations? Thanks!
Gaming (not going to be competitive gaming like I used to, just something to do when I am bored), very little photoshop and video editing.
Really looking to spend under $700 for the Motherboard, CPU, Memory, SSD and Video Card
Southern, Ilinois
Motherboard, CPU, Memory, SSD, Video card
Will be re-using 2 of my 250GB WD drives for storage
Coolermaster 1000W Real Power Pro
Coolermaster Stacker 830 Case
6) Will you be overclocking?
Most likely not
Currenty 1440x768, will plan on upgrading the monitor later this summer to a 21-23" monitor (currently 18.5")
This weekend
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
Nothing specific, SATA 6Gb/s, Crossfire/SLI possibility would be nice if I decide to run 2 cards, RAID for future SSD expansion.
Yes, 64bit Windows 7 Pro
AMD 6000+
DFI Lanparty 590SLI
2x 8800GTS's
4GB of memory
Intel i5-2500k
Asus Sabertooth P67
Southern, Ilinois
Most likely not
This weekend
