New system now or wait for VIsta?
stevo.k
I just got some year end bonus money and am due for a new system. I'm looking at a total cutting edge system with an x6800, a 680i mobo, dual 8800GTX in SLI, etc.
I've thought about building myself, but honestly, I just want a fast system with no hassles. My uses are for gaming (flight sim X), Photshop with massive file sizes and some video editing.
At this point I've narrowed it down to the following vendors:
Overdrive
AvaDirect
Maingear
I've priced comparable systems with the usual suspects, Voodoo, Alienware, Falcon, Widow, Puget but dollar for dollar, component by component, the first three seem to be a better value.
I've got money burning a hole in my pocket and would like to pull the trigger and order before Christmas, but I'm hesitant with Vista looming around the corner. So my questions are:
1. Should I buy now and wait for Vista SP2? or will Vista be stable/mature enough out of the box?
2. Everyone is offering a coupon for Vista once it's released, would I be better off waiting for systems to ship with it?
3. What do you think of the 3 system builders I am considering?
I appreciate any advice.
~Stevo.K
1) if you need a system now, then don't wait. the config you chose will definitely run vista quite well. personally, i usually wait until at least the first service pack before switching... but i may wait even longer this time, lol.
2) why would you be better off if the system shipped with it? i guess the only advantage of that is you don't have to upgrade the windows installation yourself and possibly lose any data in the process. however, i'm not holding my breath for vista.
3) i've no opinion on those retailers. i've heard velocity micro makes great systems. look into them, too. i build my systems myself.
another thing: the X6800 isn't worth it. since you do video editing, go for a quad core, QX6700 instead, for about the same price (well, at least thats intel's intention, but they can't stop retailers from overpricing at release like they always do). so after a couple weeks, the quad core extremes should be the same price as the x6800.
Alright, fair enough, no advantage to waiting for Vista.
How does the quad core take to OC'ing?
Still would like to hear opinions on system integrators.
Anybody else?
3.7Ghz is pretty impressive, although the temps are higher than I'd want to run it. The systems I'm looking at are water cooled, including both GPU's.
BTW, the three system builders all had good reviews over at [H]OCP.
Someone here must have some firsthand experience with them.
I think most of us in Gen Hardware build our own and only have experience from the [H] reviews. If you want opinions on integrators check out the Computers and gadgets section. They have reps from most of the integrators that will usually chime in to support their company.
Thanks, I wasn't sure if this was the right place to post, I'll try over there.
