New System/New Sound Card ??
Scratch
After some research I've decided to make the leap to Vista 64 os for my new build.
My greatest dilemma now is, what to do for sound. My Creative Audigy still does its thing well, and I may be able to get drivers that work with Vista 64 at the Creative site. Or, I can look at another Creative card.
PC Gamer had a review on the Creative X-Fi Titanium Fatality Pro, about a year ago. They claim that they showed about a 15 % drop in frame rates using this card. Not the way I really want to go.
Onboard sound is Realtek 889A.
I'm going to keep my Altec 4.1 speakers as I'm still loving their sound. (also getting low on funds ;))
Any help with my sound choices will be very appreciated.
Thanks,
Scratch
Realtek 889A is excellent onboard audio. Which Audigy do you have, if its a 1 - you might be stepping down putting something from Creative in there.
The 889A has much better specs than the original Audigy, and in my opinion does just fine for games, entertainment, or music.
889a does 24bit/192khz (better than Blu-Ray)
108DB snr DAC
104DB snr ADC
The snr basically defines the noise floor - 108DB is incredible.
depending on your motherboard you might get Dolby Home Theater (or one of the others) (which would do real-time encoding to dolby digital with any input) This is nice if you have a reciever and watch movies on the PC.
Audigy does 24bit/96khz (most studios master at this rate)
Audigy DSP
96DB snr (not stated which direction)
The newest cards:
woop up on the Realtek - at least on paper.
Your own ears are a better judge though.
PC Gamer just reviewed the Creative PCI-E Fatality Titanium and they showed an increase in FPS.
Many thanks for your help.
Looks like I'm going to have to search around for a few online reviews.
I do prefer a sound card solution. First to improve frames and also to take advantage of EAX, which I found to work nicely in games.
I suspect that my old Audigy is an early model, (SB 1394).
Spenny: My Nov 2008 issue of PC Gamer states, when commenting on the Titanium and Xonar:
"Strangely both cards had a bigger impact on frame rates - as much as 15 percent - than the PCI- based X-Fi Fatal1ty card. This is surprising if you expected, as I did, to see better frame rates as a result of the higher bandwidth of PCI-E.
This reads to me like a negative impact on frame rates. (unless my dyslexia is kicking in)
Believe me, I'd like to be wrong about this.:confused:
Btw: Motherboard is the new Gig EP45-UD3R.
Also my comment re the Gamer review in my first post was in error, with reference to the issue date. I was looking at the Nov 08 issue.) Sorry.:eek:
Cheers!
