New system, I think it died! help!:(
duncandun
Hey guys, having computer problems... :(
I got my system up and running this morning(amd 4000+, 7800GT,2gb corsair, a8n premium board) I got windows installed, etc. did all my drivers from my mobo/gfx discs, I downloaded the ones from nvidia, then installed and restarted, i went into bios to look at my cpu temps and such. Noticed my cpu was only running at 1.4ghz instead of the 2.2 it should, i upped the multiplyer from 6.5 to 10. saved and exited.
Black screen.
Thats all i get, black screen, it owersup fine, all the fans work, the red LED ont he mobo is off though, and all i get (only sometimes, as well) is a black screen.
Anyone have any ideas?
i was running 33C on the cpu according to the bios, the problem is i can't get to the bios because all i get is a blackscreen, no POST or anything...
Okay do this ... on the mobo there is a small CMOS battery take it out for 10 seconds stick it back in THEN try!
Removing the battery RESETs CMOS and it'll reset the BIOS since it can't remember, i've had this problem before.
Woot, Thanks! this did it, completly forgot about it resseting the bios:) thanks!
YAY!!
Also I think it's a good idea to refain from BIOS tweaking unless you know what you're doing.
BIOS is good but too much can be bad! ...
yeah last night i was messing around with my OC and it just suddently did not want to work. i exited BIOS and it would come up with a black screen no matter what. so i reset cmos and it works fine. i duno why it did that though
