I need to set up a workstation to serve apps and store files on for a company i just started. Basicaly there will be a main PC( the 1 in question here) and then 2 laptops that I need to connect to it from out in the fiels via VPN.
So here is my parts list I have put togeather so far. I guess I would like some input. Like do I need to go with raptor HDD's or should I just use 16mb buffer 7200 rpm HDD's? suff like that. if there is costs I can cut that would be great. If there are things I need to add I would like to know so I get it right the first time.
Thanks.
Update Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
Model #: Nine Hundred
Item #: N82E16811129021
Return Policy: Standard Return Policy
In Stock
$139.99 -$20.00 Instant $119.99
Update ASUS M2NPV-VM AM2 NVIDIA GeForce 6150 Micro ATX AMD Motherboard - Retail
Model #: M2NPV-VM
Item #: N82E16813131014
Return Policy: Limited 30-Day Return Policy
In Stock
$89.99 $89.99
Update SeaSonic S12 II SS-380GB ATX12V 380W Power Supply - Retail
Model #: SS-380GB
Item #: N82E16817151032
In Stock
$74.99 $74.99
Update AMD Athlon 64 X2 5000+ Brisbane 2.6GHz Socket AM2 65W Black Edition Processor Model ADO5000DSWOF - Retail
Model #: ADO5000DSWOF
Item #: N82E16819103194
Return Policy: Processors (CPUs) Return Policy
In Stock
$129.99 $129.99
Update A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model ADQVE1A16K - Retail
Model #: ADQVE1A16K
Item #: N82E16820211066
Return Policy: Memory (Modules, USB) Return Policy
In Stock
$56.99 $56.99
Update Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
Model #: WD1500AHFD
Item #: N82E16822136011
In Stock
$184.99 $184.99
Update Western Digital Raptor WD360ADFD 36GB 10,000 RPM Serial ATA150 Hard Drive - OEM
Model #: WD360ADFD
Item #: N82E16822136054
In Stock
$99.99 $99.99
Update LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-06 - Retail
Model #: LH-20A1L-06
Item #: N82E16827106072
In Stock
$36.99 $36.99
Update Microsoft Windows Vista 32-Bit Business for System Builders Single Pack DVD - OEM
Model #: 66J-02289
Item #: N82E16832116207
Return Policy: Software Return Policy
In Stock
$149.99 -$10.00 Instant $139.99
Subtotal:
Thanks.
In Stock
Model #: M2NPV-VM
In Stock
$89.99 $89.99
Model #: SS-380GB
In Stock
$74.99 $74.99
In Stock
$129.99 $129.99
Model #: ADQVE1A16K
In Stock
$56.99 $56.99
Model #: WD1500AHFD
In Stock
$184.99 $184.99
Model #: WD360ADFD
In Stock
$99.99 $99.99
In Stock
$36.99 $36.99
Model #: 66J-02289
In Stock
Subtotal:
