New System Help...
tuffgong
OK I'm beginning to piece the parts I want to buy together...all I gotta know is whether they are compatible with each other because I haven't been keeping up with all the new releases...
MOBO - ASUS "A8N-SLI Deluxe" nForce4 SLI Chipset Motherboard For AMD Socket 939 CPU -RETAIL
CPU - AMD Athlon 64 3200+, 512k L2 Cache, The Only 64-bit Windows Compatible Processor - Retail
RAM - Corsair XMS Extreme Memory Speed Series, (Twin Pack) 184 Pin 1GB(512MBx2) DDR PC-3200 - Retail
VIDEO - Leadtek nVIDIA GeForce 6800 Video Card, 256MB DDR, 256-Bit, TV-Out/DVI, PCI-Express, Model "PX6800TD-256M" -RETAIL
HARD DISK - Two WD Raptor Series 36.7GB 10,000 RPM SATA Hard Drive Kit, Model WD360GDRTL, Retail
For all the other parts I can figure it out, but is this core good enough and would you buy something similar?
One 74Gb Raptor is likely to be substantially faster than 2x36Gb even in RAID 0, except for certain specific tasks. I would get one 74Gb drive if it was my choice.
Make sure the CPU is socket 939 to match the motherboard of course! Also, if you are going to get SLI, it would be best to get one 6800GT now, rather than the 6800 non-Ultra that you've specified. The GT is substantially quicker and if you ever come to add a second one to the SLI board, they'll fly.
Does this look like a good system? It comes out to about Two Grand
ANTEC Performance Plus Case with 430W Power Supply, Model "PLUS1080AMG" - Retail
Specifications:
Case Type: SOHO File Server
Color: Antec Metalic Gray
Material: 1mm SECC Steel
Drive Bays: 5.25" x 4/0, 3.5" x 2/4 (external/internal)
Expansion Slots: 7
Front Ports: 2xUSB & 1xIEEE1394
Power Supply: 430W
Cooling System: 3x80mm installed Fans
Mainboard Compatibility: up to Extended ATX
Dimensions: 20.6"x8.1"x18.6" more info-> N82E16811129115
Specifications:
Supported CPU: Socket 939 AMD Athlon 64FX/64
Chipset: NVIDIA nForce4 SLI
FSB: 2000 MT/s
RAM: 4x DIMM DualChannel DDR 333/400 Max 4GB
Slots: 2x PCI-E X16(SLI mode: x8,x8), 2x PCI-E X1, 3x PCI
Ports: 2x PS/2, 1x LPT, 10x USB2.0(Rear 4), 2x RJ45, 2x SPDIF out, 1x IEEE1394, Audio Ports
IDE: 2x ATA 133 with NV Raid 0/1/0+1
SATA: 4x SATA2 3.0Gb/s with NV Raid 0/1/0+1, 4x SATA with Raid 0/1/0+1/5 by SI3114R
Onboard Audio: Realtek ALC850 8-Ch
Onboard LAN: nForce4 built-in Gbit MAC, MARVELL GbitLAN
Onboard 1394: 2x 1394 ports
Form Factor: ATX more info-> N82E16813131517
XFX nVIDIA GeForce 6800 GT Video Card, 256MB GDDR3, 256-Bit, Dual DVI/TV-Out, PCI-E, Model "PVT45GUD" -RETAIL
Specifications:
Chipset/Core Speed: nVIDIA GeForce 6800 GT/350MHz
Memory/Effective Speed: 256MB GDDR3/1000MHz
BUS: PCI-Express x16
Ports: TV-Out(S-Video/Composite) + 2x DVI
Support 3D API: DirectX 9.0c(Shader Model 3.0), OpenGL 1.5
Max Resolution@32bit Color: 2048X1536@85Hz
Cable/Accessories: S-Video/Composite Cable, Power Cable, 2x DVI to VGA Adapter , Manual, Driver CD, Games
AMD Athlon 64 3000+, 512KB L2 Cache, Socket 939 64-bit Processor - Retail
Specifications:
Model: Athlon 64 3000+
Core: Winchester
Operating Frequency: 1.8GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/ 512KB
Voltage: 1.5V
Process: 90 nm
Socket: Socket 939
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Warranty: 3-year MFG
CORSAIR XMS Xtreme Memory Speed Series, Xtra-Low Latency 184-Pin 1GB(512MBx2) DDR PC-3200 w/ Platinum Heat Spreader, Model TWINX1024-3200XLPT - Retail
Specifications:
Manufacturer: CORSAIR
Speed: DDR400(PC3200)
Type: 184-Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2-2-2-5
Support Voltage: 2.75V
Bandwidth: 3.2GB/s
Organization: two 64M x 64-Bit
Special Features: Plug-n-FragTM Auto-Configuration - Boots automatically using the Xtra-Low latency values of 2-2-2-5
Alps Silver 3.5inch Floppy Disk Drive, Model DF354H168F, OEM
Specifications:
Capacity: 1.44MB
Average Access Time: 3 ms (track to track)
Interface: 34 Pin Standard Floppy Connector
Form: 3.5 inch
Media Type: All Standard 1.44MB & 720KB 3.5 Floppy Diskettes
Features: High reliability attained by the employment of a direct-drive motor
Western Digital Raptor 74GB 10,000RPM SATA Hard Drive, Model WD740GD, OEM Drive Only
Specifications:
Capacity: 74GB
Average Seek Time: 4.5 ms
Buffer: 8MB
Rotational Speed: 10000 RPM
Interface: Serial ATA
Features: High Performance SATA Interface
SAMSUNG 910T-Silver 19" LCD Monitor -RETAIL
Specifications:
Panel Type: a-si TFT/PVA LCD
Native Resolution: SXGA 1280x1024
Pixel Pitch: 0.294 mm
Brightness: 260 cd/m2
Contrast Ratio: 1000 : 1
Response Time: 25 ms
View Angle: 170 / 170 (Horizontal / Vertical)
Input Connectors: 15pin D-Sub, DVI-D
Dimensions & Weight: 16.4" x 16.7" x 7.5" (WxHxD), 15.7 lbs
Manufacturer's Warranty / Phone No.: 3 years parts, labor and backlight / 800-726-7864
Dead Pixels Policy: Replacement or Refund for 8 or more DEAD PIXELS ONLY! more info-> N82E16824001161
SONY 16X DVD-ROM Drive, Model DDU1613, OEM
Specifications:
Read Speed: 40X CD-ROM, 16X DVD-ROM
Interface: E-IDE / ATAPI
Buffer: 512KB
Access Time: DVD-ROM: 80-220ms, CD-ROM: 165ms
Data Transfer Rate: 1,800 ~ 3,600 KB/s CD, 8,788~21,632 KB/s Single Layer DVD, 5,586 ~ 13,520 KB/s Dual Layer DVD
Features: Compatible with all CD formats, Mounting: Horizontal or Vertical.
NEC 16X Double Layer DVD±RW Drive, Sliver w/ Software Model ND-3520A, OEM
Specifications:
Write Speed: 16X DVD+R, 8X DVD+RW, 4X DVD+R DL, 16X DVD-R, 6X DVD-RW, 48X CD-R, 24X CD-RW
Read Speed: 48X CD-ROM, 16X DVD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
OS Support: Windows XP/ 2000/ ME/ 98SE
Features: High speed writing performance.
