Case Lian Li Silver ATX Mid Tower Case, Model "PC-6077" - $125
http://www.newegg.com/app/ViewProductDesc.asp?description=11-112-043&depa=0
Mobo - MSI K8N Neo Platinum - $149
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=241132
PSU Antec 480W Power Supply with Blue LED Fan, Model "TRUE480BLUE" RETAIL - $76
http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-914&depa=0
CPU AMD Mobile Athlon 64 3200+, 1MB L2 Cache, 64-bit Processor 62W OEM - $284
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-445&depa=0
HS Thermalright Copper Heatsink for both Intel and AMD, Model "SLK948U" RETAIL - $39.99
http://www.newegg.com/app/ViewProductDesc.asp?description=35-109-114&depa=0
HSF Panaflo 92mm High Output w/ RPM - $9.99
http://heatsinkfactory.com/cgi-bin/HFAstore.pl?user_action=detail&catalogno=CF-036
RAM OCZ Enhanced Bandwidth Series Platinum Edition 184-Pin 1GB(512MBx2) DDR PC-3500, Model OCZ4331024EBDCPE-K - Retail - $310
http://www.newegg.com/app/ViewProductDesc.asp?description=20-146-983&depa=0
HDD - Western Digital Special Edition 120GB 7200RPM IDE Hard Drive, Model WD1200JB (**bought a year and a half ago)
Sound Creative Labs Sound Blaster Audigy2 ZS PCI Sound Card, Model "SB0350" RETAIL - $88
http://www.newegg.com/app/ViewProdu...-102-162&catalog=57&manufactory=BROWSE&depa=0
Speaker Klipsch ProMedia ultra 5.1 Personal Audio System - $354
http://www.newegg.com/app/ViewProductDesc.asp?description=36-119-106&depa=0
Video Radeon X800 XT Platinum Video Card, 8x AGP, 256MB 1.12GHz GDDR3 $499.99
http://www.compusa.com/products/product_info.asp?product_code=313032
Keyboard, mouse, monitor, DVD-ROM and OS are already bought/old components.
Waiting for Dual Layer DVD-RW
Total without tax, shipping: $1935.97
Could you guys please comment on my prospective rig setup? My current rig, which is a Dell 866 MHz back in 2000 is getting old so based on some research, Ive come up with the setup above.
1. Are all parts compatible to each other?
2. Would I be able to overclock the CPU better if I had a greater rating of ram? (above pc 3500?)
3. If overclocked, how much MHz would the CPU go up to without adding more fans or going liquid cooling?
4. If you guys think some of the parts might need a change, please recommend.
PS: Besides the ram I have up there Anyone have any opinion on the two Ram sticks below?
http://www.newegg.com/app/ViewProductDesc.asp?description=20-146-934&depa=0
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80097-08
