New System Help! P5N-E-SLI 6600
ezish
Hello everyone,
I am going to buy the following system. I really wanted to buy 680i chipset however, it scares me with the problems people are having with it. I am basically looking for the following things:
Things I want in my system:
1. External SATA port on the motherboard
2. I am not a huge over clocking fan or care about it a lot. However, If I have the option for sure I will look into it and make use of it. The only problem is that I need to make sure I have a good cooling.
3. The games I am going to play for now, i don't thing they require 2x8800GTX. So, I think only one is good enough. The only concern I have a 23" Wide Screen Monitor and that might be a problem. I am using 1920x1200 and hopefully with 1x8800GTX it is not going to be a problem to maintain that resolution.
4. Fast PC. Performance is important.
5. A lot of RAM because I am going to use some Virtual PC
My System Configuration:
· Intel Pentium 4 Core Duo 2.4 GHZ 6600
· P5N-E-SLI nForce650i
Note: I am note sure. Should I get Intel 975 or P5N32SLI or ????
· CORSAIR 800Mhz Twin2X2048-6400 2x1GB
· CORSAIR 800Mhz Twin2X2048-6400 2x1GB (Yes, 4 GB RAM)
Note: I don't think there is much difference between brands as long as I am going with 800Mhz except with SLI Ready. Since I am not getting 680i no point getting a SLI Ready RAM
· EVGA GF 8800GTX 768 MB PCI-E
Note: I believe they have the best customer service and that's the only reason I am going for EVGA
· Western Digital Raptor 150 GB
Note: As far as i know, RAID 0 won't give me a significant performance benefit, so I am going with only one 150 GB Raptor)
· Creative SB XiFi Xtreme Gamer Fatality
Note: I know, the store I am buying it from they don't have XtremeMusic. Fatality is a bit more expensive and i don't think i actually need this.
· BFG (BFGGR1000W) 1000W ATX Power Supply
Note: The guy at the store ask me to get this incase in the future I buy one more 8800GTX
· Antec P180 Black Advance Super Mid Tower Case
Now it will be greatly appreciated if you guys give me some comments and recommendations.
Everything here is based on my research knowledge. So if I am wrong please let me know.
Ezish
evga 680i has had a hardware revision and is fine now
6600 is ok. i have one of them, too.
you can get 4gb memory kits now for around $350-$400 with 2x2gb sticks so you can upgrade to 6gb or 8gb later
http://www.newegg.com/Product/Produ...170147+1052108080+1052315794&name=4GB(2+x+2GB)
evga vid card is good
raptor 150 is good. dont worry about raid 0 with that drive.
re think the sound card, especially if you are going to use vista. get an auzentech if you must have a sound card.
you dont need 1000watt psu, even for 2 gtx. a 750 to 800watt etasis/siverstone or seasonic will be swell.
case is pretty much up to your taste as long as it has decent airflow. p180 ok, might want to put the money you saved on ram and psu towards a lian li.
Thank for the reply.
- For the case it is kinda hard to decide. These days there are some cases with water cooling support. I feel that if I go for water cooling my pc will be very slient.
- I think i am going to use Vista, so that Creative Xtreme Fatality sound card doesn't support Vista yet?
- How am I going to the difference between an old EVGA 680i motherboard vs. the new hardware revision EVGA 680i?
- How much important it is to go for SLI READY ram? (http://www.slizone.com/object/slizone_build_psu.html)
if you go watercooling drop the antec P180 case for something better like eg an armor or Lian li case that you can mod, unless you want the radiator to be on the outside of the case...
why don't you buy a 680ui mobo then or the inbetween solution P5N32-E SLI plus ? As you spend loads of cash on all other hardware. At stock all run fab and most of the child diseases are gone...
I really don't see the point in gaming at those resolutions isn't 1280 at 1024 sufficient for you guys with all detail maxed out... I don't think it's worth the money spend on another GTX card
SLI ram ain't worth the extra cash as you can set the timings yaself and mostly with 4 gigs you will run into trouble. If you con't overclock get some normal PC6400 ram max , don't bother at timings as they don't deliver so much to general gaming performance. I second the claim in buying 2 X 2 gigs sticks instead of 4 x 1 gig ones. Get the Cas6 from Gskill they run fab according some users...but you will need a Vista 64 version to take benefit of the ram....
if you go watercooling drop the antec P180 case for something better like eg an armor or Lian li case that you can mod, unless you want .......
What are the benefits getting a P5N32-E SLI plus vs. P5N-SLI-E?
What is PC6400 ram max?
Why 4 gigs will cause trouble?
I don't think I will use any 64 bit Windows. No point using it yet. I can't run any 32 bit software and hard to get lots of drivers..right?
the new rev evga 680i's are the ti and the a1. the old ones, which you probably cant get anymore are the ar and tr. there is also a newer model the 680i lt (lite?) that is $50 cheaper and doesnt have as many features, but more features than a 650i sli. its reviewed on the front page.
Another concern I have is all my old IDE drives. I have 1 hard drive and 1 DVDRW Drive. I heard the Intel 975 is not good with IDE. How about the P5N-E-SLI?
