New system for a friend
cupholder2.0
This system will be used as a server. It must be able to perform very cpu intensive tasks for extended periods of time. It must also be able to handle some occasional gaming. Now here is what I am thinking so far.
CPU
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
$319.99
Motherboard
Video
EVGA 320-P2-N811-AR GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130082
$279.99
Memory
2X A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail (4 GB Total)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
2x$86.99
Case
Hard Drives
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
$109.99
Optical Drives
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner With 12X DVD-RAM Write - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106070
$30.99
LG Black 52X CD-R 32X CD-RW 52X CD-ROM 2MB Cache E-IDE / ATAPI CD Burner - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136059
$17.99
CPU COOLING
Power Supply
SILVERSTONE ZEUS SST-ST65ZF ATX12V 650W Power Supply 90 - 264 V - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817163108
$109.99
It would be helpful if you guys could fill in the missing components. I am not really in sync with the latest tech so I am not aware of whats on the market right now.
A server and you are sticking a 8800gts in there. Some people just have money to burn I guess. I wonder what your gaming computer is like... :D
What about the IP35-Pro? The reviews on the board look good. Can I expect the board to run 24/7 and be under high load?
What do you think about the power supply? Also what is so good about the Thermalright?
Would this be able to compare with the thermalright?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103026
BTW this system is for my friend, who will buy it with his money, lol. I am far too cheap to buy something this expensive. He wanted a high end video card for some reason...even though he will use it mostly for business purposes.
I don't know why people here are so partial to Abit and Asus. I have the Gigabyte P35-DQ6 and it is great. It is made well and runs cooler than the others. Running cooler should mean something to someone that is building a PC that will be running all the time
Thanks for the suggestion. Will consider the P35 DQ6.
