I've finally graduated from college and found a job, and I've decided it's about time that I bought myself a new computer. The last time I build a computer from scratch was 2002. Since then I've bought a Dell which I modified, but just isn't up to today's gaming.
I've been browsing the forums here for some time, but only registered today to get some opinions on my build. I will initially be using a lot of parts from my existing computer, but will eventually replace these parts so that I can leave my existing computer intact and usable.
--edit - i forgot to mention what i'll use it for--
So basically I'll be using this rig for development - hobby programming, freelancing, etc (web and application)
And also I'll be using it for gaming. I play wow and eve often enough, as well as a few different FPS's.
--/edit--
First, here are the parts I will be reusing:
2 Hitachi Deskstar 250GB HDDs (SATA, raid 0 setup)
Creative X-Fi XtremeMusic
Dell 2405fpw 24" screen (1920x1200, new rig must push games at this level)
Here is what I've got so far:
MAINBOARD:
ABIT IP35 Pro - I weighed this board against similar boards from ASUS and Gigabyte, but I've settled on this one.
CPU:
Intel Core 2 Quad Q6600 - Lots of OC potential, quad core to boot.
MEMORY:
mushkin 2GB (x2) DDR2-800 (5-4-4-12, 1.8v) - Lower voltage for OC potential
OR
mushkin 1GB (x4) DDR2-800 (5-5-5-12, 1.8v) - Possibly better than the 2x2GB solution? Not sure if spreading the memory out this much will outweigh 5-4-4-12 vs 5-5-5-12.
CPU COOLING:
Tuniq Tower - Great air cooling for an OC'd Q6600
OR
Zalman CNPS9500 - Maybe great air cooling for an OC'd Q6600?
The CPU cooler is important so that it can both cool the Q6600 and work effectively (and fit) into the case I would like to use
CASE:
Antec P180b - Couldn't find the P180b at Newegg for the link. This case has been all over the forums here. It's beautiful, but I'm worried I may have problems using it with an air-cooled setup. I was originally inspired to use this case from tim987's post here.
PSU:
Corsair 520W w/ EPS12V - I won't be using an SLI setup but I would like the option to do so in the future. I am assuming the 520W will be more than enough to power my rig, if not then the 620W and 720W are around.
GRAPHICS:
EVGA GeForce 8800GTS (new chipset) - It's nice.
Overall I think it should make a good rig. Any advice is appreciated; I'd rather get it right than regret it. I won't be purchasing anything until mid to late January, so I've got a while to sit on it.
THANKS!
--/edit--
MAINBOARD:
CPU:
MEMORY:
OR
CPU COOLING:
OR
CASE:
PSU:
GRAPHICS:
THANKS!
