new system build problem
slampy
this is the first system I built.
abit an8 ultra
corair xms 1gb pc4000
evga 7800GT
seagate 120gb sata2
enermax whipser 2
it is not seeing my keyboard all the time. so when I go to install windows I can't "hit any key to boot from cd" so I thought it might be the usb ports on the mobo, but it still works sometimes. I already installed windows, but I didn't know I had to install the raid drivers first, so it kept crashing. that is why I am trying to reinstall it, but now the keyboard isn't being see. I figured I would hook it up to my old computer so I can go online, but it doesn't recognize the keyboard either. I don't know why, cuz I was using that computer just a few days ago. is it something in the BIOS that I need to fix? afterall the very first time in booted the new computer I was able to install windows. i just can't think of what it could be. any ideas? thanks. let me know if I need to describe the problem better, lol.
Well, I figured out that I needed to enable the usb keyboard setting in CMOS before it would work. however there are only optoins to use the keyboard in BIOS or in the OS, I don' know why. so when I have it set for BIOS, it will not see the keyboard after I go into windows.
my new problem is that even though I am now able to boot from cd, I can't hit F6 to install teh RAID drivers. when I boot the windows xp cd on the bottom of the screen it says hit F6 for raid instalation. but when I press F6 it doesn't do anything. I rapidly press it, too.
Has anyone else had these problems with thier Abit AN8 Ultra boards? please help me out. thanks.
have you up-dated the bios,you could try using a ps2 interface keyboard for set-up needs
I have a abit an8 on the way for an opty build,I like the looks of these with the uguru features
I thought the nforce4 chipset had native support for SATA, meaning you didnt have to install drivers before installing windows???
