New system build, need advice.
Wolve
My current Rig is danm near 7 years old.. it has held up good.. but now with games such as Fallout 4 and Black Ops 3 among other awesome titles coming out, its nearing the time to start a new build..
Its been so long ive been out of the hardware loop for many years.. today i was tinkering around tigerdirect and i seen this one Motherboard but the price seems abit hefty to me.. thou i do know it is a combo deal with a CPU..
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=9805491&Sku=
But typically im a AMD guy..
I want to build something that can handle on normal settings games of today and the future.. im not into hardcore ultra high quailty, as long as it looks decent i am happy..
But i also want to build something that i can upgrade if need be down the years from now.. something that will last long such as my current system did..
now with all this in mind.. i want to start building something that wont cost an arm and a leg..
or my fiancee may have my head lol to be blunt lmao..
I would like to stick to AMD CPUs since ive used those in the past.. so if anyone can throw me some good wisdom on the latest AMD boards that dont run to high that fits into what im looking for into putting into my current system project.. id appreciate it..
Something that will last into many years while just sticking to normal quality.. i dont really do overclocking or extreme graphics and wont cost an arm and a leg.
i do like the look of some of the Mobos that have thermal Armour on this.. but does that fancy Armour looking stuff really work or is it just for show and reason to jack up the price?
That is definitely a solid starter combo. Pair with some very fair priced DDR4 ram and you have the beginnings of a well balanced system. As per AMD, I don't know a bunch on that so I can't help you there
Well crap lol I like the stats on that Intel board but the price is iffy due to a fiancee who is overwhelming tight at times on funds lol never ordered anything off tiger before, do they do payments or finance?
It's a once in 6 years upgrade with that CPU, or should be. That is a really good price for whats is in that combo
ROUGHLY, where are you located?
Just trying to see if you're near a MicroCenter, as you can score some awesome CPU+Board deals there.
Like the same board and an i7 6700k (4Ghz part), would run about $470.
And the same board and an i5 6600k (3.5Ghz part), would run you about $388.
Also, would you be recycling anything from your current rig?
I am in Minnesota, but i put in an order for it so, cant wait to start on my build! now to find a nice case that will match with the Mobo, was thinking something white off Tiger Direct, I seen this one that was called Snow edition or something? looked interesting.,
Good cases that come in white
Corsair Graphite 600T, 760T, 780T, Air240 & 540, Carbide 500R
NZXT, Phantom, H440
I am currently running an AMD 6000+ windsor waiting for the new AMD Zen and AM4 motherboards due sometime in 2016. There is nothing on the AMD side for me to recommend unless you get a free hand me down from someone else upgrading like i did.
