new system build help needed !!
shkj
Hi All,
I was wondering if i can get some help...I have an Asus A8V-Deluxe mobo
My sons 4 yr old computer just died it's an Athlon XP 2600+...So rather than try to hunt down a new socket A board I think what I want to do is give him my A8V motherboard and 3200+ venice !!...This way I can get a better socket 939 board and processor and not have to buy new the new DDR-2 RAM and still be with in my budget !!!!
Now where to start for me...I can tell you that building a new Intel Core2 Duo is definatly out of the question money wise...my wife absolutly said no to spending more than $400....!!!!!!!!!!!!!!!!
B do have 3 gigs of Patriot Low latencyDDR-400 RAM (Low timings of 2-3-2-5)
I think I do not want to overclock right now however get a board that allows me to do so down the road...which on do you recommend ??
As far as CPU I think I definatly will go will an Opteron either the 180 (2.4) or the 185 (2.6)
however what is the best way to get past 2.6 GHZ and still be stable ??
As far as a PCI express video card since I DON'T PLAY GAMES AT ALL I'll use the Quadro FX560 that was GIVEN to me by a freind (128 meg card)
Between the motherboard and CPU is $400 is do-able ???
remember this is kind of a "high-end" Workstation !!!
I'll still keep my raptor drive for my O/S and apps
Bottom line what configuration is going to give my a noticable difference and screaming performance from my A8V & 3200+
Thanks in advance...shkj
