I have been a member of HardForum since 2002, but haven't been on here much the last few years as my system has been working fine and doing everything I have needed it to do....gotta love that Abit IC-7 motherboard!!
Anyway, it is time for a new system, and I have been very much out of the hardware loop. I recently read the article in Maximum PC in which they outlined a $1500 PC, and started to think of that as my template.
I first of all need to know if I should post a thread in each individual forum for each part of the system (which probably makes the most sense if I want specific advice) or if I can post in one forum, such as here....
My basic thoughts on a system are as follows:
I would like an Intel based system, and am definitely thinking quad-core. The article recommended the Q6600 Core 2 Quad proc (2.4 ghz), and that does seem to be a good chip. They then listed the following parts:
XFX Geforce 8800 GTS 512 Alpha Dog Edition vid card
MSI P35 Neo2-FR motherboard
4GB of Patriot DDR2/800 RAM
A cooler Master CM Stacker STC-T01-UW case
PC Power & Cooling Silencer 610 power supply
Windows XP Pro
Seagate 750 GB Barracuda AS 7200-10 hard drive
An optical drive
and finally the Creative X-Fi Xtreme Gamer soundcard
I already have XP Pro, and would probably get Vista, and do a dual boot system.
I already have 2 optical drives, they are a few years old, but seem perfectly capable.
I am having trouble finding the CM Stacker case, and wonder if there are better options out there?
I do a lot of gaming, and have done some overclocking in the past with my Abit board. I don't know how important it will be to OC in the future, but would like to be able to do some.
If I can build something with similar or even better results than the above for less than $1500 I would be ecstatic.
I currently have a 19" Mitsubishi Diamond Pro 900u monitor that is working ok, but I would like to enter the world of larger monitors, and have absolutely no idea where to start with that....that will be down the road a bit.
I would welcome feedback on the above, and if I need to post questions in individual forums for each of the specific parts, I can do that too. It kind of saddens me that when I built my last system, Abit had one of the best boards out there with the IC7, and now it seems their reputation has slid quite a bit....
Thanks in advance!!!
Steve
Windows XP Pro
An optical drive
Steve
