new swiftech product
DFI Daishi
well, it's time for them to roll out the update for their seldom used MCW50-T
http://www.swiftnets.com/products/mcw60-T.asp
i'm glad that they include a reasonably powerfull pelt with it, since i had to take the pelt out of my maze 4-1 block because it is only an 80 watt and it wasn't likely to help with GPU load temps.
just a heads up because this is one application where you don't necessarily need a dedicated PSU to run a pelt, assuming that you have a really beefy 12 V rail feeding your 4 pin molex connectors.
I wonder how two would fair with twin X1900XT's and a 680 watt power supply.
jeez....i should really verify my links before i paste them..... :rolleyes:
as for a pair of them with a 680 watt PSU, that's 18.6 amps sucking off of your 12 V rail. i think that your PSU would most likely be hard pressed to dish that out in addition to running the rest of the system, but as always, check the specs for your specific unit. pay special attention to how much 12V amperage you have and make sure to note if it's on a single 12V rail or divided among 2 rails.
