new Swiftech 3a or 3?
pigdog2
Swiftech just came out with a new revision of there H2O-120 that has the pump and reservoir together to fit in a 5.25" drive bay. The question is since they had to make room for the pump the reservoir seems to be half the size of the version 3 one. Wouldnt less coolant equal less cooling ability? Thinking of getting a Swiftech kit for a new system I'm going to build. THX
added coolant volume does not make much of a difference on the whole.
how cool the coolant stays when the system is opperating depends largely on the rad and fans.
added coolant volume will mean that it takes the coolant longer to get up to normal opperating temperatures when you first fire up the computer, but once the coolant is at opperating temperature, it doesn't matter how much you have as long as the loop is full and free of air.
