New stuff for my rig
Status
Not open for further replies.
robble
After I put my 7970 on water and overclocked it it became obvious my 240 radiator couldn't handle the load of o/c'ed cpu and gpu at the same time. So it's time to get additional radiator!
Just got this in the mail today. I'm still waiting for amazon to ship my new case that it'll all fit in.
not bad, but what are rpm's on those fans you have there, the rad you got is pretty thick, so you should really be rocking some 120x38 fans for it with a decent rpm.
Gentle typhoon AP-14's that I'm going to use in push/pull. Should have plenty static pressure and stay quiet. I'm also still going to be using my swift tech 240 so I should be fine.
I have 3 AP-30's that would push massive air but they are much too loud for me (well, for my wife).
I knew they said fin density was high but seeing it in person make you go wow.. Don't need a filter for this radiator as it's almost like a filter itself.
You haven't seen high fin density until you've seen GTS radiators. Trust me, I have both the GTX and the GTS, and the GTS makes the GTX look sparse.
I had never even looked at the fpi of the gts - I saw stealth in the name and figured it was made for low speed fans.
30 fpi - guess not! wow. For me wanting quiet i think the gts might be a bit too air restrictive although it is thinner so I don't really know which would be harder to push air through.
Status
